Erson Cam question.
Erson Cam question.
I have an Erson Viking 100H cam that was previously installed in this 455 I'm building. I've never heard it run, but it was very low mileage running motor (rebuilt) before it got swapped out for an undisclosed brand of engine. It seems as though the cam events do not coincide with the timing chain marks being at 6/12 like the Factory OE Chassis manual suggests. Ive installed two timing chains to be sure, one Cloyes 3 keyway roller, and then a Cloyes 9 keyway, and TDC on compression occurs when the timing marks are 12/12 for both.
Can someone verify (Cutlassefi perhaps) that this particular cam has to be degreed starting with the timing marks at 12/12?
Going a little nuts here.
John
John
I think John's point is that with the marks at 12-12, he expects the no. 1 cylinder to be at TDC on the EXHAUST stroke, and at 6-12 to be TDC on the COMPRESSION stroke. Instead he's getting the opposite with this cam. Obviously it doesn't matter from the standpoint of engine function, but it's interesting if they have the cam dowel pin 180 deg out from "normal".
Will be running it this weekend. I figure Im going to have to pull and drop the distributor at least once. LOL.
