Engine wiring. Trans kickdown switch
Old Sep 27, 2015 | 07:46 AM
Microreedy's Avatar
Does anyone know if the engine harness from American Autowire include the wires that go down to the kickdown switch on the TH400 trannys or is there a separate wiring harness that plugs in?
Old Sep 27, 2015 | 11:23 AM
I can't speak to the aftermarket harness, but the factory harness had the kickdown wire built in. In fact, it was included even on cars that did not require it, like manual trans and TH350 cars. If the aftermarket harness is an accurate duplicate of OEM, it will be there.
Old Sep 27, 2015 | 12:15 PM
Microreedy's Avatar
Will it be on the engine harness or the dash harness. Thanks for your help!
Old Sep 27, 2015 | 12:24 PM
It's part of the engine harness. It runs from the firewall connector down under the trans tunnel to the connector on the side of the trans.
rustycragars
Dec 25, 2016 06:06 PM
ctrain22
Oct 31, 2009 11:50 AM
ej69
Sep 6, 2009 09:06 AM
Skip584
Nov 22, 2008 04:42 PM
