Engine Number
Engine Number
Hi all
I have this number on the timing chain casing 396026G, have I read this right as 68-69 400ci? I am hoping I havent decoded it correctly as I was sold this as 455ci
TIA
Aaron
TIA
Aaron
Thanks for the reply, I was only checking today as I wanted to order some service parts for her. Maybe I shouldnt have trusted the dealer I bought it from so much! Only had it 48hrs an all
The bright side is that most things interchange between that 400 ("long stroke 400" G block) and the 455. Pistons and the engine block are the major differences.
As Ralph correctly points out, that is a 1968-69 G-block 400. Same crank and rods as a 455, but only a 3.890" bore vs. 4.125" on the 455. No, there isn't enough meat on the cylinder walls to take it out that far.
Thanks for the replies Gents. As we are both members of the EU I'm sure I will have some rights and I will be looking into it, whether its a refund on the price or a return. Do you guys know what the difference in price would be based on the 455 being a 400?
Unfortunately, pricing is difficult to assess. The G-block 400 was only made for two years, and only installed in the 442 and some Vista Cruisers. As a result it is relatively rare as compared to the 455 that was built from 1968-1976 and used in nearly all full size Oldsmobiles, Toronados, GMC motorhomes, 1970-up 442s, etc. Obviously these are MUCH more common. On the other hand, the G-block 400 was not one of Oldsmobile's better engines. The relatively tiny bore and long stroke made for less than ideal breathing and more than a few grenaded when used for racing. The reality is that the G-block is only desirable to someone restoring a 68-69 442, and even then many of those cars have been retrofitted with the more desirable 455 motors. Here in the US, any bare Olds block will sell for US$100-200. I have no idea of availability or value in the EU, unfortunately.
Thanks for the replies. The dealer has offered to take the Olds back which I do not particularly want as this would make me out of pocket by nearly 3000GBP. Is there much difference between the 400 and 455 engines? The 400 has had some work done, Edelbrock heads, Edelbrook intake manifold, high lift roller cam, Holley 850cfm and performance headers. Hotchkiss performance suspension. Wilwood 6pot calipers all round. I havent been able to drive it yet as its currently not registered so only had the test drive which was a while back now
I would also ask for documentation on this performance work done to the engine. If I was you, I would start the car up and make sure everything works and it doesn't overheat, stops well and is what you expected.
3000GBP is that 3,000 "British" pounds ? Last weeks conversion was about $1.28/1.00 pound.
I looked at his website and wasn't impressed. If you return the car, it should be at HIS EXPENSE as well as compensate you for shipping you a fraudulent item. You could negotiate down to him shipping at HIS EXPENSE a usable 455 block and pistons. You may need to consult some legal advice.
Yes, its 3000 british pounds
I agree with shipping at his expense. When test drove, we were out for a good while and put her through her paces and no signs overheating, it stopped quicker than it went so I'm confident that everything is fine on that account, no paperwork but its the only the cams I cannot see. Just the engine being not what I expected is a big disappointment. I have asked about the block but he doesnt have one, he has offered 250 euros as compensation but I dont think I can buy a 455 block and pistons for that??
You have no idea what pistons are in the motor now. Who built the engine ?
I wouldn't expect him to pay promptly, but thats just my opinion.
I'm surprised the obvious question hasn't been asked yet: What car is this 400G in? If its a numbers matching block in a '68/9 442, and if you don't intend to race it, you might consider keeping it as is, or at least keep the engine w/ the car if you swap it for a 455. Can't blame you though for using this a leverage for compensation since it was mis-represented.
So, let's review: it was represented as being a legitimate 4-4-2 (344- VIN) with a 455 swapped in place of the original 400G, but actually it's a Cutlass with 4-4-2 trim and a 400G swapped in place of the original 350.
That about right?
That about right?
