Engine miss
Old July 22nd, 2010 | 07:27 AM
Thomas Simcich's Avatar
Engine miss
1966 442 tri-power, "E" block, casting number 390925, rebuilt and bored 40 thousandth over. At idle engine runs fine. When holding a steady speed the car feels as if it is in too high a numerical gear and the car bucks slightly or feels like a miss, almost as if it should be downshifted, but when you downshift it still has the problem. Did not notice the problem during acceleration. Engine has less than 100 miles on it. 3:55 rears gears. Any ideas?
Old July 22nd, 2010 | 07:29 AM
Have you checked your transmission fluid? Perhaps your transmission fluid is low and it is cavitating and the pressure is dropping...
Old July 22nd, 2010 | 07:41 AM
Engine miss
Car is a 4 speed.
Old July 22nd, 2010 | 10:37 AM
Any other possibilities?
Old July 22nd, 2010 | 12:00 PM
Old July 23rd, 2010 | 07:24 AM
curvewrecker's Avatar
I had a broken wire in my distributor that acted that way. The wire was broken inside the insulation, so everything looked good and ran fine, except at higher revs where it would act up similar to how you describe...
Old July 23rd, 2010 | 07:42 AM
citcapp's Avatar
A bad spark plug wire cross firing or grounding out will cause that problem.
Old July 23rd, 2010 | 08:06 AM
Car has this miss problem at all speeds. The reason I am asking about this problem is I am thinking of buying this car and I don't want a major repair on my hands right away. Could there be any expensive answers to this problem? I appreciate everyone who has helped.
Old July 23rd, 2010 | 09:36 AM
If you haven't bought the car then tell the current owner that you will buy it if they fix the problem first.
Old July 23rd, 2010 | 10:30 AM
scubastever's Avatar
this is not my car lol
when you have the engine running low rpm, but hi load- the tendency to misfire is usually related bad plugs/wires/coil/cap/rotor.
check your mechanical advance as well, (are the weights free? does the actuaor hold vacuum?)
fv64olds98
February 6th, 2017 06:27 AM
russell-t
May 10th, 2012 06:38 AM
joe_padavano
Tech Editor's Desk
15
March 17th, 2010 07:35 PM
Holiday55
December 6th, 2007 05:06 AM
