Engine ID help
Old Oct 15, 2022 | 09:07 AM
Moegs's Avatar
Engine ID help
Hi all. I have taken pics of the stamped #s and the fact that it has E heads. The stampings look weird. Am I looking in the right place? Driver side pic. I know this engine is not original to the car. Can anyone tell me more?
Old Oct 15, 2022 | 09:46 AM
E heads are 1970. The stamp on the block is not a normal VIN derivative, so this was not a factory-installed block. That stamp indicates either a service replacement block or a block originally from a non-automotive application (marine or industrial). What is the block casting number above the water pump?
Old Oct 15, 2022 | 01:35 PM
Moegs's Avatar
Thanks, Joe Here is a pic of the casting#
Old Oct 15, 2022 | 01:40 PM
A serif "F" is a 455 block, TYPICALLY from 1970-72, but not always. That's about all the info you can get from the outside of this motor.
Old Oct 15, 2022 | 02:03 PM
CANADIANOLDS's Avatar
Looks a lot like the stampings I posted recently. The one I posted was a service block replaced at a GM dealer. Both have the L I SB designation and upside down. To me, it’s just a way to track or identify a factory service block. It’s a GM rebuild. This one I got is .040” over with GM pistons.
Old Oct 15, 2022 | 08:36 PM
Moegs's Avatar
Smile
Thanks, Joe. You rock! I can see from my minimal posts that you are one helluva olds guy. I'm still learning the navigation on this forum, bc I'm 71 yrs old.
Tgbunch
Jun 29, 2022 05:18 PM
ericisback
Oct 21, 2021 06:20 AM
J1978
Jun 25, 2021 04:26 PM
Nihayde
Jun 16, 2017 06:39 PM
420weblazeit
Apr 7, 2014 10:12 AM
