Engine Continues to Run
Old Apr 13, 2011 | 04:24 PM
GreekDog's Avatar
hello everyone!
I have a 72 cutlass with a 455. Just recently the battery died on me. After I charged my battery and let me car run for a few minutes I proceeded to turn the ignition to the off position. While the key was turned to off the engine continued to run for a few seconds and then finally sputtered and stopped.
This never seems to happen to me when Im driving around the city and going places. It only really happens when I start the car at home, let it idle and then turn it off.
The car runs like a watch but I just dont want the problem to start happening when Im out driving elsewhere away from my house
anyways, thanks for your time!
Old Apr 13, 2011 | 06:12 PM
Originally Posted by GreekDog
hello everyone!
Couple of suggestions:
1. Check to see if your fuel filter is plugged.
2. Check to see if your anti dieseling solenoid is set properly.
Old Apr 14, 2011 | 07:26 AM
Spark pug heat range, timing, carb to rich, etc...
Old Apr 14, 2011 | 07:55 AM
alek72us's Avatar
Olds Dreamer
I agree with oldscutlass. check ur timing. its not good for your car to do that. if u cant fix it leave it in gear turn ur key off then put it in park. safer on ur engine that way. but i would check ur timing. hopefully u get it fixed.
Old Apr 14, 2011 | 09:18 AM
J-(Chicago)'s Avatar
Seasoned beater pilot.
This also happens with a weak throttle return spring, or when there are a lot of carbon deposits on top of the pistons.
Old Apr 14, 2011 | 10:22 AM
GreekDog's Avatar
I dont have a timing light. If i were just to retard the destributer by a few degrees would that be ok or should i not adjust it without the light.
I am just getting into classic cars and I dont have many tools(I worked construction so I have all basic tools but nothing auto specific)
Would you say that a timing light is something that I should buy and use often? I know thats probably a dumb question but Im a begginer to working on cars and need advice. any other tools that I should absolutely have?(I already have ratchets, wrenches and all sorts of fittings)
Old Apr 14, 2011 | 10:53 AM
You need a timing light, a tach., an a dwell meter. Also a Volt / Ohm meter.
I'm sure we could come up with a much longer list, but those are essential.
You should be able to pick up a good tach/dwell/volt meter and timing light at a yard sale or flea market for $5-10 each.
Old Apr 14, 2011 | 11:36 AM
citcapp's Avatar
I agree, check the timing first. Then look to carbon buildup. Get out and take it for a long drive at highway speeds and then see how it acts. You can rent timing lights at most chain auto parts stores
GreekDog's Avatar
Smile
thanks eric!
My friends arent really into cars and this is my first project so I really appreciate the advise.
Bluevista's Avatar
Registered
Did you hit the gas once to get it off the choke idle before you shut it down?
Was the engine idling at the same speed it normally does when it's warmed up and you put it in park in other words.
When it's cold the choke makes it idle higher and if it was only running a few minutes and you didn't touch the accelerator pedal or carb linkage it may have still been up on the high idle.
With the throttle plate open and the high idle it can run on for a few seconds when you shut it off if you don't kick it down to the lower idle first.
Old Apr 14, 2011 | 12:02 PM
GreekDog's Avatar
i think thats the best explanation thus far. It only ran for a few minutes and i think it was at a high idle and like i said it NEVER does that when i have driven it for ten or so minutes.
im going to check the timing and idle regardless.
Im new to this site and everyone is super helpful! I really appreciate the tips!
shamusj
Mar 4, 2016 06:48 AM
BIGJERR
Feb 20, 2011 02:23 PM
rickbmac
May 19, 2010 07:53 PM
BosMobile
Drivetrain/Differentials
Apr 12, 2009 03:39 PM
Rockbottom07
Jul 25, 2007 04:37 AM
