Tools for setting the timing
Old Apr 14, 2011 | 04:31 PM
teacherofphysics's Avatar
Hi Oldsmobile fans... I want to work on my 1968 Delmont (455 w/ 4 bbl QJet) next week and was hoping that I might get some advice on what tools I need to set the timing. I am a novice, but keep learning through various experiences I have with my Olds. Regarding tools for setting the timing, is there a recommended timing light? I do not have a tach, but do have a dwell meter. I have seen timing lights with no frills, and some with several additional functions. So which to get?? And... any other tools necessary for my first attempt at setting/adjusting the timing? Thanks for any advice!!
Jerry
Old Apr 14, 2011 | 08:08 PM
TripDeuces's Avatar
Having a dwell meter is a big plus and a must have for point type distributors. Most have a built in tach with them. I have a dial back to zero timing light which can be helpful for checking total timing but it's not a must have item but it is a convenience. You can also have a timing tape for the balancer which would do the same thing with a cheaper light. If you're doing a new set of points you'll need a set of feeler gauges, screwdriver and a 9/16 wrench for the distributor hold down. Of course if you're going to spend all this money maybe it would be more cost effective to get a points eliminator kit from Pertronix, Crane, MSD, etc. Then you wouldn't have to worry about points again.
Old Apr 15, 2011 | 06:54 AM
You will need the correct tool for adjusting the pts to set dwell (it's an allen wrench, or screwdriver at the end of flexible shaft with a plastic handle). The adjustment is thru the window on the dist cap. I like the the adjustable timing light because it's simple.
Before you do any of your dist work. I would check and /or replace spark plugs, wires, dist cap, rotor, points, and condensor. If your pcv, air/ fuel filter has not been replaced in awhile, I would also consider those items. I would also inspect all my vacuum and fuel lines.
young old car guy
Jun 26, 2012 09:35 AM
russell-t
May 14, 2012 09:01 AM
The Stickman
May 26, 2010 07:37 PM
442scotty
May 13, 2009 05:42 PM
Jolly Green
Jun 27, 2008 02:21 PM
