Engine Change Time
Old Sep 27, 2005 | 08:57 PM
jdorour's Avatar
Unhappy
I overheated the 425 in my Ninety Eight last night and now it is seized tight. Looks like it's time to pull it out again and rebuild it.
Old Sep 28, 2005 | 05:47 AM
Oldsguy's Avatar
Past Administrator
Post
Or, it may have been vapor locked, if you got a cracked head or leaking head gasket and got coolant vapor in even one cylinder that would be enough pressure to seize the engine. If, after it has cooled you still can't turn it then you are probably right and have some siezed bearings.
That happened to a '76 98 I owned a few years back. #2 rod bearing siezed up tight.
Old Sep 28, 2005 | 05:39 PM
jdorour's Avatar
Post
I wish it was hydro-locked. I let it sit overnight and it will not turn. I have alrady pulled the transmission. I'll get the engine out Friday.
Old Sep 29, 2005 | 06:50 AM
EdsDelta's Avatar
The Charter Member
Post
Ugh! I know the feeling of the knot in your gut. I spun a bearing on mine almost 6 years to the day. Odd thing was, I wasn't torqing on it or at high RPM so it was fate.
Glad to still see sings of life here. Do you guys visit www.oldsmobileforums.com ?
truerollers
Feb 28, 2017 01:00 PM
Macadoo
Feb 14, 2016 01:20 PM
dre
Drivetrain/Differentials
Aug 31, 2011 11:04 AM
rgass
Feb 19, 2011 08:13 PM
