Edelbrock/speedpro Heads Spark Plug options
I am using the Edelbrock recommended plug. Champion RC12YC's
what should I get as far as plugs to change how hot the ignition gets the engine? I’m using pump gas with a 455ci and w30 style cam. Holley Sniper Quadrajet with timing control
comp ratio? And not what you think it is but what it really is.
I run NGK V-Powers. Be careful where you buy. Many companies (looking at you, Summit) will ship plugs pulled from a bulk carton, and send them loose, in a plastic bag. I pay a couple dollars more at the local, independent Carquest to have the security blanket of individual packaging.
