Edelbrock heads v.s. worked f- heads
Hey, wondering. My friend has a gto, saying it would be a huge difference upgrading heads.
Im not seeing this, as the intake/ ext. valves are the same. My f- heads are ported ext.
Opinions? Thanks
Opinions? Thanks
I think if you get honest flow numbers on your heads and match the correct cam for your application you'll be very happy. Don't be disappointed in the flow numbers, Olds heads don't flow very well, even ported. Good luck.
Dick Miller tested Edelbrock 60519 out of the box intake 253 CFM @ .700" lift & exhaust 192 CFM @ .700" lift. The valve size itself is not the pinch point restricting flow in these heads.
Truckman5000 are you sure those are "F" casting heads? Do you have any photos of the casting numbers in the center of the head by the exhaust port? The only reason I ask is the "F" casting heads are pretty rare, and usually fetch about $2500, or more, for good bare, unported castings. Those heads are usually pretty hard to find, and reserved for guys that are building a numbers matching car.
I recently did some more work on my heads and am hoping to get 300 CFM out of them. They should be going to the flow bench Thursday.
Dave,
Maybe you can enlighten me as to why you and others even bother to give flow numbers at lifts of .700? Based on what a vast majority will be building, those are a waste of time and imo nothing more than hype. What's it matter if you're not pushing the valve open nearly that far?
As you know Milan, me and others have built 600+hp projects with nothing close to that in lift(mine had .630). So for comparison purposes, don't you think maybe for the Olds community, flow numbers in the .550-.625 range would be more useful and realistic? Unless someone is using a sizable solid roller most won't even come close to that amount of lift.
Jmo, thanks.
Jmo, thanks.
So it seems that a worked stock head will flow "the same" as an edelbrock?
My car is a w-30, the F heads are #matching. They were ported 20 years ago or so by someone else.
I dont plan on the edelbrock, trying to keep it original
Dave,
Jmo, thanks.
Jmo, thanks.
Well Mark, I understand what you are getting at, and you are correct. Probably 98% of the guys on this sight, or running strictly on the street, would never have a cam that large. So why even look at those flow numbers? The reason I posted the .700” specs was because that was the highest lift they posted for the Edelbrock heads. The other reason is because my lift numbers will be higher than .600” and my flow chart is in .100” increments. I also have flow numbers up to .800” but that would be silly. The thing I found interesting is that my numbers kept going up. If someone is crazy enough toutilize fully ported cast iron heads, in an effort to compete with aluminum castings, then they might want to put as big a cam in that will work with their compression ratio. In all fairness, I feel that the numbers under the curve are probably more important than peak numbers. So let’s take a look at them-
Edelbrock: .100” 65/53 .200” 136/103 .300” 197/139 .400”242/167 .500” 243/182 .600” 250.189 .700” 253/192
Freak’s ported “C” castings: .100” 70/51 .200” 135/100 .300”185/142 .400” 223/169 .500” 251/183 .600” 265/193 .700” 273/198
Look at the .300” and .400” comparison. The Edelbrocks are significantly better. This leads me to believe with a smaller cam of say .500”lift the E-brocks would most likely perform better. I am still learning.Cylinder head flow numbers are only one piece of the puzzle. Air speed/ cross sectional area/ and port shape are even more important.
Recently I ported even further on my heads. I hope I didn’t mess them up by going too far. As soon as I get flow numbers I will post up results in the “Home PortingTechniques“ thread.
Truckman 5000, the only real way to find out if your heads flow as well as the E-brocks would be to do back to back flow testing. If it runs good now I wouldn’t mess with it. If you want to get more performance out of your combination, you will have to give us a lot more information. You may even want to talk to Mark, (CutlassEFI), about setting you up with a custom tailored cam for your specific application.
Sorry about the novel guys, just trying to explain why I posted what I did.
Carry on, Dave – The Freak
I'm currently porting a set of B heads just for something to do so any flow numbers or comparisons are appreciated by me for sure, the plan is, is to run my ported B heads and eventually buy a set of bare procomps and port them for a comparison, im following freaks guidlines in the head porting area as a reference since im used to porting chevy heads.
The reason I posted the .700” specs was because that was the highest lift they posted for the Edelbrock heads. But that still doesn't mean anything, they do it for the same reason, hype. The other reason is because my lift numbers will be higher than .600” and my flow chart is in .100” increments. I also have flow numbers up to .800” but that would be silly. Yes it would. The thing I found interesting is that my numbers kept going up. If someone is crazy enough to utilize fully ported cast iron heads, in an effort to compete with aluminum castings, then they might want to put as big a cam in that will work with their compression ratio. In all fairness, I feel that the numbers under the curve are probably more important than peak numbers. Yes they are. So let’s take a look at them-
Look at the .300” and .400” comparison. The Edelbrocks aresignificantly better. This leads me to believe with a smaller cam of say .500”lift the E-brocks would most likely perform better. I'd put something in it around .550 lift. It spends so little time at max lift you want to maximize the time it does spend at the mid lift level. I might even use something that's a little slower as well. I am still learning.Cylinder head flow numbers are only one piece of the puzzle. Air speed/ crosssectional area/ and port shape are even more important. Very true.
My filled Procomps flow better at .600-.650 than they do at .700. But all else being equal I'll bet they'll make more power with a cam around .625 lift than yours do at lifts of .700 or better.
Madmax's 480 I just did had modest flow numbers (286@.600) for ported Edelbrocks but made the upper limits of the pipemax estimate. I would venture to say it's because of the quality of flow as well as decent midlift numbers.
Hope this helps.
Hope this helps.
Hope this helps.
.25D is an equation all should learn. That is to say 25% of your valve diameter (2.07 x .25= .517) is when the actual port shape takes over and does not care about your valve seat, short side radius, and bowl shape (to an extent). On a 2.07 valve, .517 lift is when that all takes place.
Mid lift numbers can make or break an engine when you are reaching for the stars, because how many guys are going with .650+ lift cams with their Oldsmobiles?
The mid lift numbers can be improved with careful attention to the valve seat, valve shape, short side radius, and bowl work.
It depends on what you are after....
Edelbrocks will probably pick it up slightly, but that all depends on the quality of the porting on your F heads as mentioned prior. A set of Edelbrocks with attention to detail and a short block to match will do even more.......and you will probably feel it with the "seat of the pants" feel.
1969cutlass4d
June 9th, 2016 06:01 AM
KTouse
May 12th, 2013 01:58 PM
gearheads78
June 18th, 2009 02:03 PM
