Edelbrock Heads
How tall are the stock ones? I want to make sure I can still run power brakes/AC. I heard that 4" is too tall for a 455.
I am actually looking for some right now cause I am finishing a build and the engine shop needs them.
Most guy's are probably running an 8 or 9" booster. The stock valve covers I have under my bench are 2 3/4" tall. You also have to allow for the oil baffle on the inside to clear the rockers. With my Scorpions, I had to use 3/8" aluminum spacers. With the stock 12" booster, it's tight and I will have to remove the booster to remove the valve cover. When I get to that point, I'll put in a smaller one.
W30 replica intake
Q jet
Cast iron heads with stainless 2.072/1.710 valves with a little bowl blending, Solid bronze guides/ valve job/ 7/16 screw in studs
MLS head gaskets
CP Bullet pistons/7.100 H beam rods
4.185 x 4.500 stroke
Coated Clevite bearings
BTR multi hole timing chain set
ARP harware
Comp hydraulic roller 242/248/110
Harland Sharp rockers of course
OPP deep pan and pickup
Melling HV pump
ATI balancer
Steel flywh
Q jet
MLS head gaskets
ARP harware
Melling HV pump
ATI balancer
Steel flywh
I am running the 1" taller valve covers to clear my roller rockers, I had to clearance the A/C box on the firewall to make it fit. I also use a smaller power brake booster. The other thing you have to consider is your Alternator and A/C compressor brackets...I had custom brackets made but it wasn't cheap.
https://classicoldsmobile.com/forums/major-builds-projects/34212-new-engine-new-paint-new-interior-hero-camera-documented-3.html
I made a 1" spacer between the lower alternate bracket and the power steering bracket. Cut a little metal from the top bracket to clear the taller valve cover. Took about a hours worth of work. Haven't done the AC bracket yet but don't think it will be too hard to figure out depending on the AC unit I choose
http://highperformanceolds.com/phpbb...php?f=1&t=2675 This is what I wanted to post earlyter but it didnt work . AS you can see BTR has stock valve covers and HS rockers on this build up.
Lots of good info never thought a head change would require so much,i ordered arp studs and eldelbrock covers see how i make out with them.Now the fuel pump i guess is the next hurdle some say they can run stock and some electric and i am not cutting my new heads
Low and behold the stock fuel pump fits just lol got the heads on today and now i have to get a brake booster cant even get the last push rod in without removing it.My new carb and spacer will clear oai hood.So all good but alot more cleaning and painting.Have not drove it in 13 years and been in my shop for 4 so whats a little more time.
69CutlassAlex
July 30th, 2013 08:18 AM
Creativeindy
September 11th, 2012 05:38 AM
70Cutlass_408
June 24th, 2011 07:55 AM
