Edelbrock 850 or rochester 800 cfm for a 455 olds
I can get a Edelbrock 850 #1910 or Rochester 800 cfm( Mid 70s's Buick) for a 455 Olds.
Need to rebuild the stock 750 rochester with cast iron manifold.
Should I stay stock or ....Upgrade to a newer bigger carb.???
joepenoso
joepenoso
I have the Edelbrock 850 Q-jet on my engine, I love it. If you have plans for future upgrades the the bigger carb might be good. I don't think you can go wrong with any of the carbs if your willing to rebuild them correctly and take the time to dial them in.
x2
I like the electric choke too. I know you can retrofit it to any carb but its nice to have.
I am running it on a '69 400 with an edelbrock Performer, stock cam & stock torque converter and it runs really well.
I have a stock 68 400 and I went with the 600 runs great but I think I could have gone bigger. Are you running an 850? That's not to big? Steve
One other comment though - It has the fuel line coming into the side (Chevy style) instead of straight into the front so if original appearance is a factor you should keep that in mind.
http://www.everyday-performance.com/
If anybody needs a carb rebuilt he was very reasonable and got it done pretty quickly.
We flowed one of those Edelbrock 850's. They don't flow 850,not even close.A typical 455 street engine,with an iron intake or aftermarket dual-plane does not need anything more than 750-780cfm.It will not spin fast enough,or have the potential top-end power to demand anything more.
The 500" Cadillacs were supposed to have an 800cfm carb,& they don't.
The 455 Buicks were supposed to have 800cfm carbs,and they don't either.
They don't need them.
On another note,the Q-jets from the 403's don't flow 850 either.To get one that actually does,you need to look at mid 80's Chevy vans & trucks.
The Edelbrock 850 Q-jet doesn't flow 850.
You will be fine with the carb that you have.
