eagle crankshaft
eagle crankshaft
just pulled my 455 apart crank is worst than I thought has any one used an eagle crank and how did you like it they are 500 bucks thru summit seems like the way to go
Look for a used N crank first. If you can't find one then you could go for the Eagle crank. Their quality control has gotten much better but I'd still check it. Just like you would anything else.
I've had excellent results with the Eagle cranks. They shut down production early 2013 and installed a lot of new equipment. The last few I have seen are as nice as any crank you'll find and right on spec. with no taper on any journal.
Your results may vary.
84hurst
January 21st, 2011 03:40 PM
gearheads78
December 21st, 2009 08:50 AM
