eagle crankshaft
Old Feb 2, 2014 | 01:54 PM
diesel olds's Avatar
eagle crankshaft
just pulled my 455 apart crank is worst than I thought has any one used an eagle crank and how did you like it they are 500 bucks thru summit seems like the way to go
Old Feb 2, 2014 | 02:21 PM
cutlassefi's Avatar
Look for a used N crank first. If you can't find one then you could go for the Eagle crank. Their quality control has gotten much better but I'd still check it. Just like you would anything else.
Old Feb 2, 2014 | 02:48 PM
Smitty275's Avatar
Engine Builder
I've had excellent results with the Eagle cranks. They shut down production early 2013 and installed a lot of new equipment. The last few I have seen are as nice as any crank you'll find and right on spec. with no taper on any journal.
Your results may vary.
cutlassefi
Jan 7, 2013 03:32 PM
Jacoz70442
Feb 23, 2011 09:45 AM
84hurst
Jan 21, 2011 03:40 PM
TRW
Oct 13, 2010 09:27 AM
