dug out the 425
Old June 13th, 2011, 04:38 PM
wilder's Avatar
dug out the 425
well i dug out my 425 today and its in overall pretty good shape since it has been in storage for the last 5-6 years. cylinder walls look great no rust! Still will probably take it apart it give it a nice cleaning before putting into the car! Dont mind the mess!
wilder is offline
Old June 13th, 2011, 04:44 PM
citcapp's Avatar
Is it stock or built to some degree? Like the valve covers
citcapp is offline
Old June 13th, 2011, 05:36 PM
wilder's Avatar
Testing my memory now!
It’s built up pretty good
It’s a 425 30 over
High volume meiling oil pump port match to the main cap
Cut the main caps and added the straps using ARP studs
Upper and lower custom windage trays
Cam is a Comp cams part #42-000-5
240@.050 intake
246@.050 exhaust
Cloyes double roller
I degreed the cam
Comp cams lifters and pushrod
Can’t remember what rockers just remember they was high dollar will have to pull the valve cover to find out
Edelbrock performer heads also had the block drilled for 1/2 studs
Edelbrock intake with 850 Holley
All MSD electronic ign
Also did some modifications to the oil system
Did I leave anything out?
wilder is offline
steve walker
December 17th, 2019 12:32 PM
marxpups
November 18th, 2012 07:31 AM
marxpups
November 2nd, 2012 03:03 PM
BIGT82
July 11th, 2010 06:35 PM
Quick Reply: dug out the 425
