Drilling crank for pilot bushing
Old Apr 4, 2020 | 07:14 PM
oldsmoboogie's Avatar
I am going to be dropping off my crank to have it drilled for the pilot bushing. Should I have it drilled to the factory sized bushing or should I have it drilled for a roller bushing? I would like to use a bushing that is readily available at local parts stores if at all possible. If I remember correctly the last time I bought a bushing I had to order it from year one and I don’t want to deal with that again. Any recommendations are appreciated thanks.
Old Apr 4, 2020 | 08:48 PM
redoldsman's Avatar
Proud Viet Nam Veteran
I think the ball bearing bushing and the bronze bushing drill to the same size. No personal experience but I have read some folks have had cases of the ball bearing bushing coming apart and recommended the bronze bushing. I am sure others with some experience will speak up.
Old Apr 5, 2020 | 05:21 AM
65B01Delta's Avatar
Auto Zone has them in stock, if not they can order it... I used the bronze.
Old Apr 5, 2020 | 05:31 AM
The original factory bearing IS a roller bearing.
Gary M
Dec 31, 2016 11:42 AM
citcapp
48
Mar 30, 2014 03:40 AM
oldsmosteel
Apr 28, 2013 12:39 PM
Olds Dad
Jul 20, 2011 04:57 PM
ROBZ442
Mar 2, 2011 08:13 AM
