Dorman 594-117 harmonic balancer
Old Jun 14, 2018 | 03:46 PM
Gascoop's Avatar
This is a stock replacement part for many GM engines ....so would it be reasonable to assume that it would hold together for an occasional 5,000 rpm blast? .....sorry, also which is a better part for just cruising around and again an occasional full throttle run. A cast iron or aluminum water pump .......... thanks
Old Jun 14, 2018 | 05:09 PM
RetroRanger's Avatar
72 Olds CS
Im sure the dorman is a fine unit, i used the DAYCO PB1147N Premium. Its about the same price and to me the dayco name intimates its a better quality part....
Old Jun 14, 2018 | 06:52 PM
Gascoop's Avatar
Thanks Ranger, I'll look it up.
Old Jun 15, 2018 | 09:08 AM
oddball's Avatar
On water pumps, rumor has it that aluminum housings can deteriorate and develop leaks if not driven regularly. It's the pull of the belts on the nose. I'd stick with the parts store replacement pumps if the car isn't driven much and you're not looking for the aluminum bling.
Old Jun 15, 2018 | 02:13 PM
Gascoop's Avatar
Ranger/oddball ...... I bought the Dayco PB1147N Premium, paid $76 shipped....good deal, thanks Ranger. I 'll be using the flow cooler 1776 alum. pump which is the 5.65" unit. It will only have one belt on it driving the water pump and alternator, will use a Spahl elec. puller fan. thanks for the info.........Dave
Old Jun 17, 2018 | 12:40 PM
maddoctor's Avatar
I had the dorman but had a weird vibration at highway speed, I just changed it to a higher cost unit, 250 bucks, but it not only took away that vibration but it even seems to idle better.
Old Jun 17, 2018 | 03:45 PM
I would use caution in relying on Dorman's application list. For example, they claim it fits Oldsmobile from 1964-1980. The 1964 330 motors have a unique TDC mark location and will not interchange with balancers of other years (unless you scribe a new timing mark on the balancer for that motor).
Old Jun 17, 2018 | 04:06 PM
maddoctor's Avatar
Yes my new balancer is a fluid damper model, big bucks but it is worth it. Vibrations can shake an engine apart if left long enough.
Old Jun 18, 2018 | 05:10 PM
edzolz's Avatar
What about the 330 motors that had the counter weight and no actual balancer? I have one off a 67 330.
Old Jun 25, 2018 | 02:24 PM
Gascoop's Avatar
Just an update, and headsup for anyone looking, I received the Dayco balancer today, glad Retroranger recommended them. VERY nice piece, the machine work is excellent.
griffey57
Feb 17, 2017 04:18 PM
wizard
Tech Editor's Desk
Jun 28, 2013 05:25 AM
wizard
Jun 27, 2013 07:50 AM
Stevec
Aug 19, 2012 05:20 AM
dallasite21
Mar 20, 2011 03:02 PM
