Customer Build 455
Old Feb 11, 2020 | 06:21 AM
69Chrgr's Avatar
Customer Build 455
Building this one for another Olds customer.
1970 .030 455 Block. Line bored, .honed, cam plugs, .010 polished crank, Eagle Rods, SRP Pistons (I'll try to provide specs on pistons and cams later), "C" heads, bowl ported, 2.075 Intake and 1.78 Exhaust Ferrea valves, Competition valve springs setup for roller cam, Howards, roller cam, 4/7 swap, Howards roller lifters, new pushrods, screw in studs, Comp roller tip 1.6 rocker arms, W30 aluminum intake (repop), W30 exhaust manifolds, Dick Miller Q-Jet build to match combo.
Old Feb 11, 2020 | 10:02 AM
cutlassefi's Avatar
You do realize that rocker is at its limits with the spring pressures needed for a roller cam correct?
And I’m guessing the piston is really a CP and the ex valve is a 1.68? That’s what they look like anyway. Thank you for the build outline!
Old Feb 11, 2020 | 10:23 AM
69Chrgr's Avatar
No I did not. That's a good point. Thanks for pointing that out. Yes, typo on exhaust valve. Didn't know the piston was a CP either. Going to check everything here as I go, as all of my prior Olds build have been very stock. Thanks for the feedback.
Old Feb 11, 2020 | 10:24 AM
69Chrgr's Avatar
The pistons say SRP, but maybe they are rebranded.
Old Feb 11, 2020 | 11:46 AM
cutlassefi's Avatar
Do you have a part number by chance?
Old Feb 11, 2020 | 11:58 AM
69Chrgr's Avatar
I'll try to get it when I get home from the office.
Old Feb 12, 2020 | 04:09 PM
cutlassefi's Avatar
Anything on this?
Old Feb 13, 2020 | 03:07 PM
69Chrgr's Avatar
Old Feb 13, 2020 | 04:17 PM
cutlassefi's Avatar
Got it thanks. What’s your target comp ratio? Cam specs?
Old Feb 13, 2020 | 04:43 PM
69Chrgr's Avatar
9.75:1 CR. I’ll provide cam specs shortly
Old Feb 13, 2020 | 05:01 PM
69Chrgr's Avatar
Here’s the cam specs. 4/7 swap.
Old Feb 13, 2020 | 05:57 PM
truckman5000's Avatar
W30
Idk.
cutlass would know.
but I have sort of the same / bigger set up. I had to go with the bigger/ gold rocker arms. Barely fit under the valve cover too
Old Feb 13, 2020 | 06:01 PM
cutlassefi's Avatar
You keep mentioning 4/7 swap, why?
Kind of a small cam. Won’t make much hp but should enhance low end torque.
Thanks.
Old Feb 13, 2020 | 06:49 PM
BackInTheGame's Avatar
You keep mentioning 4/7 swap, .
I think I understand what 4/7 swap is referring to, but what is the logic?
TIA
Old Feb 14, 2020 | 04:10 AM
69Chrgr's Avatar
Thanks.
I didn't really seek out the 4/7 swap, it just kind of ended up with what we picked out for a street setup. However, I can tell you I used a Howards cam with the 4/7 swap on a Chevy 409, and it definitely smoothed out the idle. That cam was impressive with that combination, and the customer was and is extremely pleased. So I went with another Howards on the Olds to see if the outcome would be similar.
Old Feb 14, 2020 | 04:40 AM
W30
My roller cam is a 338, and idles fine,
Old Feb 14, 2020 | 04:50 AM
69Chrgr's Avatar
That's good. Just seeking feedback, that's all. This customer is very much a purist but wanted some kick for his 67 442. I wanted to make sure I have enough vacuum for the power brakes. Not trying to set any records, but hoping to make him a nice torquey street machine.
Old Feb 14, 2020 | 05:55 AM
cutlassefi's Avatar
That Cam is fairly small for a 455, you’ll have plenty a vacuum.
Old Apr 24, 2021 | 05:26 AM
ijasond's Avatar
Purveyor of Polyurethane
Reading this thread to me is like turning the tv to Univision...
Old Apr 24, 2021 | 07:50 AM
cutlassefi's Avatar
So you did a back to back with the exact same cams other than the 4/7 swap and it made a noticeable difference in the idle? What were the cam specs?
jmos4
Nov 14, 2020 06:29 PM
Gary M
Dec 15, 2019 06:18 PM
VinMichael
Oct 17, 2019 08:42 AM
Gary6684
Sep 28, 2019 06:35 AM
2oldsguy
Jun 2, 2018 06:28 PM
