I got a minor oil leak and as I've been told it must be the crankshaft seal. How do I get to that seal? What do I have to dismont?
Are there tightening torques I have to mind? Do I need new crank bolts?
It's a 1952 Super 88 with the original 303 (Engine is still in the car and I'd like to keep it like that)
Front or rear of crankshaft? Front is straightforward replacement of seal, rear will require major work. Sometimes the rear original rope seal will leak less with use and operation. Good luck ~
Advice from another 52 owner - Let it go if it is minor. I put cardboard from large boxes under one of my cars when it will sit in garage. Even with proper tamped installation of a quality graphite impregnated rope seal can still seep oil if the engine is not operated regularly. They do settle down with use and heat-cold cycles. If you want it done best practice is to remove engine and replace the seal out of car.
You can consider the modern replacement neoprene lip seals but it is still not 100% on leak free operation. Normal 1952 303 running oil pressure even with thick oil at cold startup should not exceed perhaps 60PSI, maybe 15-20 idling hot in gear. Big oil pressure is not needed and will make running leaks worse.
Good luck
It's leaking a LOT, since almost 7 years now and I want it to stop :P
I leave a rainbow trace when it's raining...
I got a minor oil leak and as I've been told it must be the crankshaft seal.....
Originally Posted by R_CK_R
It's leaking a LOT, since almost 7 years now and I want it to stop....
OK - Lot of miles? Very worn main bearings contribute to rear main leaks, and to front seal leaks in the transmission. If there is a bottled 'pour it in' product for running engine oil leaks I'm not aware of any that work. Best of luck ~
This is not an easy fix with the engine in the car. You need to drop the oil pan, then loosen all the main bearing caps, then remove the rear cap. Then you need to use a "sneaky pete" tool to pull the new rope seal section into position above the crank. Replace the other half in the rear main cap, then put it all back together. It's almost easier to just pull the engine
oh no. This looks like a lot of “fun” 😏
I’ve already dropped the oil pan yet but I can’t get the main bearing cap screws open.
is there any trick or are they left threaded?
do I have to use heavy tools? I don’t want to break anything 😳
sorry for all my stupid questions but do I have to remove the transmission?
where can I get this “sneaky pete” tool?
