Crankcase bolt size❓
Old September 23rd, 2019 | 09:13 PM
Josh Robb's Avatar
Hi im trying to figure out what size the crankshaft bolt size is ❓ i am trying to break it loose on a 1972 oldsmobile cutlass supreme 455, thank you. 👍
Old September 23rd, 2019 | 09:40 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
The big one on the front, center of the crankshaft is 1 1/8".
Old September 23rd, 2019 | 09:49 PM
Josh Robb's Avatar
Ok great thank you ❗️ Much appreciated 👍
Old September 23rd, 2019 | 10:56 PM
OLDSter Ralph's Avatar
Are you trying to figure out the hex head size or the thread size ? 1 1/8" sounds about right for the hex head of the bolt.
Old September 24th, 2019 | 05:56 AM
It's also torqued to 160 ft-lbs, so you either need to use an impact wrench or you need to hold the engine to prevent it from turning. I made a tool by welding a pipe to an old crank pulley. Replace the pulley with this tool and it makes loosening and tightening much easier.
Old September 24th, 2019 | 11:07 AM
Josh Robb's Avatar
Got it thanks again fellas❗️👍
Stone0204
May 14th, 2017 02:02 PM
brown7373
Tech Editor's Desk
17
June 9th, 2014 06:57 AM
Sampson
December 18th, 2013 07:18 AM
nj_cutlass72
December 27th, 2011 08:25 PM
hawks70
June 15th, 2011 11:07 AM
Quick Reply: Crankcase bolt size❓
