Cost to Rebuild a 455
Old May 23, 2010 | 09:49 AM
Axeni's Avatar
Hey guys I know this is a loaded questions with a million and one answers.
What I have is a 1970 88/455. It runs good. But it is ugly and needs to be cleaned and painted up. There is no sense to pull a motor to clean up and paint everything may as well rebuild at the same time.I am wondering what I should expect to have it freshened up, pistons, rings,bored. Hopefully being able to reuse crank and connecting rods.
Ideas and suggestions appreciated.
________
Live Sexy Cams
Old May 23, 2010 | 10:27 AM
Warhead's Avatar
Check shops in your area.
Complete rebuild would probably start around $2000, that varies depending on where you live, and depending on wear and tear. The valve job alone, could be from $200-$600 depending on what parts need replaced, and where you live.
Try to find some one local with Oldsmobile experience.
More will chime in with recommendations.
Where you live would help with that.
Put that in your edit sheet.
Jim
Old May 23, 2010 | 10:35 AM
Axeni's Avatar
Excellent thanks much. I live in Southern Ontario. If anyone wants to chime in with someone in the area they worked with :-)
________
Washington Marijuana Dispensaries
Old May 23, 2010 | 02:20 PM
442scotty's Avatar
Canada is gonna cost you a lot more...for a good job with top line parts and balancing...done properly.. Im gonna say 3000-3500 with the shop doing the assembly
1973olds98
Mar 10, 2018 12:21 PM
cobalt
Dec 21, 2013 09:02 PM
INTRUDER
Oct 3, 2012 04:15 PM
442dreamer
Aug 23, 2011 07:28 AM
Nailhead 88
Mar 4, 2011 07:21 AM
