Corrected firing order, now car won't start / backfires
Old Feb 10, 2016 | 03:47 PM
Jake Mack's Avatar
Hey all,
After reading around some, I kept seeing the 1-8-4-3-6-5-7-2 firing order being THE correct firing order for the 425 in my '67. Reading this, I inspected motor to find that someone had completely scrambled that order, so I corrected it (foolishly not documenting what order it was in previously.. lesson learned), thinking that would resolve the issue of the car being hard to start at times even after being totally warmed up, as well as a few other bugs in the starting process. I tried to start car twice, VERY briefly, and got a backfire each time. I'm assuming the timing is far, far off, now? Am I correct in thinking so?
Also, thanks to the help from another member, I discovered someone had put timing tab on upside down at some point. Who knows what else someone did to the poor girl.
I read this post VERY carefully, as well as other suggestions to other members with backfiring issues of making sure I'm starting in the right spot:
So my question is this: what should I do/not do next to ensure I won't mess something up royally? I did see in a couple other threads a process of finding TDC through compression at the plug, then seeing where rotor is pointing, making sure that part in the distributor is correct.
I thank you all IMMENSELY for your help and any insights!
Old Feb 10, 2016 | 03:52 PM
nonhog's Avatar
Registered car nut
I think you are right on track with the TDC on one then inspect. Really can't mess that up?
Maybe its a tooth off?
Old Feb 10, 2016 | 04:01 PM
wr1970's Avatar
Sent pm. I never used that diagram as it not what is in tuning guide. Chilton or Mondello book.I guess you can put Number one where you want.
Old Feb 10, 2016 | 04:15 PM
That is the correct firing order and the wiring positions for an hei. The engine does not care where #1 is wired to as long as the rotor points to it when the #1 cylinder is on the compression stroke. You may have your distributor 180 out or 2 wires crossed.
Old Feb 10, 2016 | 04:32 PM
wr1970's Avatar
I would love to see you advance that distributor When you are against the fire wall per his drawing. Your depiction Eric is correct.Like i said you can put # one where you want i just do it per the drawing you showed.
Old Feb 10, 2016 | 04:59 PM
coppercutlass's Avatar
Chevy budget Olds powered
FWIW i found that the hei example eric shared works like clockwork for me and is what i always set it to when firing up a new engine or restabbing the dist. . I always had issues trying to set #1 in a more beneficial spot for advancing reasons. WR1970 i can still get 20 initial with the set up eric showed and im running an HEI., advancing the dist. would peg the vac. advance closer to the firewall ., i think you mean advancing not dis advancing ??? not sure what you mean on that one a. Personally i would start from scratch. FIND tdc on the compression stroke and all that fun stuff.
Old Feb 10, 2016 | 05:07 PM
Yellowstatue's Avatar
Retarding
Old Feb 10, 2016 | 05:08 PM
hahaha yes the only time its politically correct to use retard lol !!!
Old Feb 10, 2016 | 05:10 PM
wr1970's Avatar
Copper the op diagram is what i am talking about not Eric's. Yes dis-advance oops.So i corrected the post.LOL
Old Feb 10, 2016 | 05:11 PM
Jake Mack's Avatar
Thank you all so much! Great points all around. And Eric, I believe it is an HEI setup, but your diagram shows the #1 one spot clockwise as opposed to that diagram I put up. Still doesn't matter where #1 is, right?
Old Feb 10, 2016 | 05:16 PM
Neely i see what you are talking about now yes that would cause issues lol. I dont know why they would put #1 so far away. I was taught years ago to put #1 facing towards the #1 cylinder. Dunno if its right but it works lol.
wr1970's Avatar
Your vacuum advance will hit the fire wall. That is why i use the one in Eric's picture which like i said is in the books. That is the little pod on the side of the dist. I hope this helps.
Old Feb 10, 2016 | 05:18 PM
Jake Mack's Avatar
Excellent.. I'll give this idea a try, then if it doesn't work, do the entire process. You guys are more than helpful. And funny.
Old Feb 10, 2016 | 05:22 PM
tru-blue 442's Avatar
Old School Olds
As long as #1 IS at tdc, the rotor will be at #1 where it is on the cap. Then just follow through with the rest of them.
Old Feb 10, 2016 | 05:24 PM
This is exactly how I run mine. My #1 is actually before the terminals. I wanted to make sure I said what I did right and visuals always work better. I religiously leave markings on my manifold and dist. for references so the only thing i can screw up is wether or not im on tdc on the compression stroke.
Old Feb 10, 2016 | 05:27 PM
wr1970's Avatar
Mine is just like yours copper!
Old Feb 10, 2016 | 05:48 PM
Old School Olds
I haven't run HEI in a while but I used to put #1 where you have #8.
Personal preference I suppose.
Old Feb 10, 2016 | 06:50 PM
sammy's Avatar
Sammy70 455 Supreme
Yup, it works....
Old Feb 10, 2016 | 07:14 PM
Like I said the engine does not care where #1 is as long as everything is set/wired correctly. I don't know why they chose 2 different positions for #1 for pts vs hei.
Old Feb 11, 2016 | 08:41 AM
TripDeuces's Avatar
Always makes me laugh when people get so wrapped up on where #1 should be.
Old Feb 13, 2016 | 10:14 PM
cjsdad's Avatar
Any time I change out a cap and wires I run the wires first then change the rotor around so it lines up correctly. Dad taught me that trick, dress the wires where you want them and then adjust the distributor to where you want it.
File Type: gif
File Type: gif
Old Feb 13, 2016 | 10:29 PM
z11375ss's Avatar
Senior Moment Member
Your dad obviously knew his way around a motor. I do the same thing. It makes it much easier.
Old Feb 20, 2016 | 12:42 PM
Jake Mack's Avatar
Hey all.. been a bit before I had the chance to work on the car again. Finally figured out #1, TDC, and got the firing order right. Now, the car is spitting a gas mist out of the carb when trying to start.. what should my next course of action be/what do you think it is?
Old Feb 20, 2016 | 12:58 PM
The timing may be too far advanced, turn the distributor ccw an inch. It may be 180 degrees out, put the #1 wire in where #6 is and rewire from there, or pull the distributor and rotate the rotor 180 degrees and reinstall.
Old Feb 20, 2016 | 01:10 PM
Jake Mack's Avatar
My thoughts, exactly.. I tried adjusting the dist., thinking it's 180.. I'll post what happens!
Thanks, Eric!
Old Feb 20, 2016 | 01:31 PM
Jake Mack's Avatar
It was 180 - out. Great call, Eric, and thanks once more! Fired right up. Nice n' smooth.
Old Feb 20, 2016 | 01:54 PM
Don't ask me how I knew... I will say your not the first, good job.
Old Feb 20, 2016 | 02:15 PM
Jake Mack's Avatar
Ha!.. never good to be the only one. Thanks again!
stevengerard
Sep 10, 2014 03:17 PM
69sAndrew
Oct 24, 2009 10:57 AM
72rocket
Dec 30, 2008 08:31 AM
monahans10
Mar 9, 2008 07:58 PM
oldcutty
Sep 14, 2006 09:20 PM
