Converting small valve Ga heads into large valve Ga heads
Old April 2nd, 2013, 04:39 PM
Hawk1061's Avatar
I am curious if anyone out there knows whether it is possible to take a set of small valve Ga heads and convert them to large valve Ga heads?
If yes, what would need to be done to accomplish this? I assume it would take machining work but how extensive would they need to be machined? Would it be expensive? Looking for someone who knows.
Thanks.
Hawk1061 is offline
Old April 2nd, 2013, 05:08 PM
cutlassefi's Avatar
Just did it on this last iron headed build I did ("455 dyno run").
The stock G heads had mostly 30 degree seats. Depending on what cam you have you'd probably benefit by going to a 45 degree seat with the larger intakes.
Get a reputable shop to cut in the new valves and do a minor bowl blend. It will be money well spent.
cutlassefi is offline
Old April 2nd, 2013, 06:44 PM
Octania's Avatar
1) buy new or at least larger valves
2) have the machine shop fit them.
It's as easy as it gets. The difference is what, 0.072" at the most... Thirty five thousandths inch cut. No worries. I had the 403 2" intakes put in the #6 heads when prepping them for my 403. You may wish to price around first, prices vary. As does workmanship. It'd be nice if they got your valve stem heights right.
Octania is offline
72Cutlass_Sunfire_Yellow
September 8th, 2014 08:38 AM
joesw31
September 7th, 2014 02:18 PM
oldzy
May 2nd, 2012 09:04 PM
RAMBOW
February 21st, 2011 08:22 PM
76Supreme350
November 9th, 2010 01:17 PM
Quick Reply: Converting small valve Ga heads into large valve Ga heads
