Clearance for OAI air cleaner/hood
Hello all, looking to see if anyone has put an edlebrock performer 2151 intake on a 455 with a OAI air cleaner/hood. Will it fit with no issues ? Looking to change . Is it much of a change from original intake besides looks and lighter. Thanks
Dave
Dave
Hi Dave
Out of the box it won't fit as its too tall. But I think there's an old thread discussing the possibility of milling it. If you can't find it with the search function I hope someone else can help. John
As you are looking for an O4B, be aware that there were two flavors. They were offered with either a square bore (Holley) bolt pattern or a spread bore (Qjet) bolt pattern. The casting carb flange is actually "unisex", but the bolt holes vary.
If you're willing to "alter" your aircleaner you can get lots of room for clearance. Here are some pics of the drop base going into the aircleaner. I run a Torker Intake with the stock breather.
Did you ever find the article about milling down the Performer intake to work with OAI hood? Been searching for it. Stock intake height is 3.30" Performer is 4.95. Wondering how much would I need to cut off for my Ram air hood to fit.
There are some other ideas in this thread... https://classicoldsmobile.com/forums...arance-144272/
Of course, I'm sure the "butt dyno" says that there's an improvement...
Here's what WILL work with an Original OAI hood , air cleaner lid and metal base, using an Edelbrock performer intake. ( note : no mods to the special OAI parts! Looks pretty stock as the performer intake looks similar to the factory W30 intake but with better flow ! ) Now the bad news : Remove the intake and have the top milled down to roughly 1/4 "'above the rest of the intake including mount for dash pot. The limiting factor is having threads for mounting the Carb ( Quadrajet) and clearing the HEI if equipped ( mine is ). My car originally had a 350 so air cleaner metal base is for a 350 - I added fitting at rear of intake for pvc adjusted snorkle an drilled housing for tubes from both valve covers to air cleaner using the 455 longer tubes. Obviously the Carb spacer can't be used with this set up. Oh I also removed the rubber seal in the bottom if the OAI lid for added clearance ( the snorkle prevents it from going down to far.) and test fit closing hood slowly! I modifled my " 350 " foam seal but need a new 455 seal due to cutting too much off at rear. I also lightly clearanced wire screen at back of hood that was scraping OAI near firewall . Works like a charm - looks stock! Good Luck
Tom
Tom
You might want to ask yourself, "How much am I hurting the flow in that manifold by milling it?" People do heroic things to try to stuff incompatible manifolds under an O.A.I. hood. All that milling and drop base air cleaner effort isn't helping flow into the engine. Typically a smaller plenum isn't what you want for performance, and disrupting the flow from how the manifold was designed isn't going to improve it.
i have always wondered the same thing. I worked with a guy who was building a 383 Chevy for his truck. He bought a brand new Performer RPM manifold for it, then had a machine shop cut a section from the center divider under the carb. He said he heard that helped airflow. My thinking is if not having the center divider helped performance, the company who cast and machined it (a company who’s very business IS performance!) would have designed without the center divider.
I’ll never understand the shade-tree gearheads who think they know more than people with flow benches, dynos, and other test equipment.
Tom
Tom
With all due respect , the OP just wanted to know if the Performer would work with the OAI parts - it will .
I not an engineer, but I'm sure the milling involved ( threads for carb are the limiting factor .) Results in an intake that flows better than the stock (Olds) one.
