Carb. interchange
Old Sep 24, 2008 | 02:39 PM
Pfiffle's Avatar
Carb. interchange
I have a "new" rebuilt 4 barrel Rochester Qjet correct for a 1976 350 Cutlass. My 1970 Olds 98 455 needs a carb. Can I use this on my 98? I've noticed the Vac. break assembly is different. Thanks.
Tom
Old Sep 24, 2008 | 02:44 PM
Tom
You can use it but it won't be jetted properly. On the other hand, it's a testament to the Qjet that the engine will probably run acceptably.
Old Sep 24, 2008 | 03:12 PM
Pfiffle's Avatar
OK. Thanks Joe. I'll get the correct carb. Just trying to save a few bucks but if it won't run the way it should then I'll wait.
Tom
Old Sep 24, 2008 | 03:28 PM
Tom
It will run OK for most uses (I've done this). You can change the metering rods later if needed.
Old Sep 24, 2008 | 07:01 PM
Metering rods cost less than $5.00 new from Summit.
Old Sep 25, 2008 | 07:54 AM
BILL DEMMER's Avatar
Just the facts...
other major differences include:
primary jets
power piston spring
secondary metering rods
fast idle cam
choke stat and coil opening rate
air bleeds and passage restrictions
accelerator pump squirt volume
air valve spring wrap
and most of the set up adjustments
yes it may "work", but likely, not very well compared to the carb. that should be on top of that '70 455.
bill
2blu442
Aug 8, 2012 07:48 PM
jon1957
Brakes/Hydraulic Systems
Apr 11, 2012 11:47 AM
D. Yaros
Aug 15, 2011 09:43 AM
<Ryan B>
Dec 18, 2005 07:02 PM
Jake Lydey
May 16, 2005 06:52 AM
