Can't get my 455 to start.
Old Aug 31, 2021 | 09:23 PM
455Jimmy72's Avatar
Hi so I'm new to this forum thing so bear with me, lol. So I have rebuilt a 455 olds an have put it into my 72 GMC Jimmy. The motor was in it when I got it. I have everything hooked up correctly I believe. Problem is I can't get it to fire. What I'm dealing with is I have power to my coil and power to the distributor but I have no spark coming from the coil which was brand new with the rebuild. Before I condemn a brand new coil I figured I'd hop on here and ask for other thoughts first. Any how thanks for your help and time.
Old Aug 31, 2021 | 10:14 PM
What type of distributor do you have? Points, GM HEI, or something else?
Old Sep 1, 2021 | 12:08 AM
455Jimmy72's Avatar
Points. I would love to install a different type but currently don't have the funds to do so.
Old Sep 1, 2021 | 04:37 AM
Rallye469's Avatar
So then are the points in good shape and the condenser?
An you can test a coil easily with an multimeter/ammeter.
You’ll be testing the primary and secondary fields for an Ohm range.
-peter
Old Sep 1, 2021 | 04:52 AM
I deleted your double post.
Here's an excellent thread on troubleshooting points ignition. I @$$ume your running points ignition.
https://classicoldsmobile.com/forums...gnition-76706/
Old Sep 1, 2021 | 06:03 AM
redoldsman's Avatar
Proud Viet Nam Veteran
First thing I would do is check the gap on the points. Then I would try a new condenser. The ones coming out of China (just about all of them) are crap. Good luck.
Old Sep 1, 2021 | 06:28 AM
^^^THIS! Be sure the points are gapped properly and that the wire from the distributor to the negative side of the coil is not shorted anywhere (a shorted condenser will have the same effect).
The points just open and close the circuit from the coil to ground. If the circuit never opens (ie, shorted wire, shorted coil, or incorrectly gapped points), the magnetic field in the coil never collapses and thus no spark is created.
Old Sep 3, 2021 | 08:34 AM
oletrux's Avatar
Good grounds?
Old Sep 3, 2021 | 02:38 PM
Originally Posted by oleetrux
Good grounds?
If the grounds were bad, the car wouldn't crank. The only "ground" in the ignition system is the wire to the points, which we talked about already.
Old Sep 4, 2021 | 07:06 AM
oletrux's Avatar
Yeah, brain fart. Sorry to interfere.
Custlasss1972
Jun 15, 2023 05:46 PM
455Jimmy72
Sep 1, 2021 04:52 AM
Stevec
Sep 9, 2014 04:10 PM
anthony r
Apr 6, 2013 08:28 PM
liquidpower
Dec 30, 2010 09:20 AM
