Camshaft for 425 in 73 Cutlass Supreme
Old Oct 1, 2024 | 08:55 AM
Donovan Carl Moser's Avatar
I've got a 73 Cutlass Supreme with a 3.42:1 posi rear end.
The engine is a rebuilt 1967 425 from a Delta 88, it has 10.25:1 compression, an Edelbrock Torker intake, an Edelbrock Performer carb, Edelbrock aluminum heads, headers, and a Mondello JM 22-25-10 camshaft.
The engine setup works, but I think I went too aggressive on the cam and intake for casual street use and cruising.
I'm thinking of changing to a Performer intake and a milder cam and would welcome any recommendations.
Old Oct 1, 2024 | 10:59 AM
68post's Avatar
I hope your eddy carb is an 800, I can't see using anything smaller on a dualplane. Or upgrade to a built Qjet.
Old Oct 1, 2024 | 11:06 AM
cutlassefi's Avatar
Why do you think you need a smaller cam?
That cam really isn’t that big for a 10.25:1 425.
What converter do you have in the car now?
I would recommend the regular Performer intake though. That’s a good all around piece.
Old Oct 1, 2024 | 01:09 PM
Since I looked up the cam specs I figured I'd post them for others:
JM-22-25-10 Hydraulic Camshaft
0.512 Intake lift / 0.523 Exhaust Lift
274° Advertised Intake Duration/280° Advertised Exhaust Duration
230° Intake Duration @ .050 / 236° Exhaust Duration @ .050
110° Lobe Separation
Old Oct 1, 2024 | 04:57 PM
SY2455's Avatar
70 442 W-30
That is a great cam, ran 1 for 17 years and it worked great with power brakes and AC. I used it with both a 3.08 posi and 3.91 posi differential. The only difference is I was running it in a 455 Oldsmobile. I really like the idle and overall driving manners.
Old Oct 2, 2024 | 07:36 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
As said, add the Performer and more stall, if necessary, easy. The factory stall and single plane intake won't be an ideal combo, 1600ish stall, if still in the trans.
rjh45
May 16, 2022 10:55 AM
jk828
Apr 13, 2022 06:13 PM
Oldsmobiledynamic88
Dec 14, 2020 04:52 AM
69CutlassAlex
Jul 30, 2013 08:18 AM
fast67vellen2o
Jun 26, 2011 03:01 PM
