Cam specs question...
Old Sep 14, 2023 | 03:33 PM
72455's Avatar
1972 U code Supreme
When I bought my U code '72 Supreme, I was told it has a W30 cam, but the PO didn't have the specs.
Well, he found the spec sheet and turns out it's not a W30, but is it W30 specs?
Old Sep 14, 2023 | 06:12 PM
There were five different camshafts used in W30 motors between 1966-72. None of them match that aftermarket cam.
Old Sep 14, 2023 | 06:52 PM
Originally Posted by 72455
When I bought my U code '72 Supreme, I was told it has a W30 cam, but the PO didn't have the specs. Well, he found the spec sheet and turns out it's not a W30, but is it W30 specs?
Same person who said they changed the rear differential fluid? Couldn't help myself, Dave.
Selective memory, or selective amnesia.
Old Sep 14, 2023 | 07:04 PM
VC455's Avatar
Barely Registered
Your cam card shows specs that are between the 1970 W-30 synchro (402569) and 1971-2 W-30 synchro (409759) but much closer to the milder 71-72 version.
Last edited by VC455; Sep 15, 2023 at 05:04 AM. Reason: corrected fat-finger part number
Old Sep 14, 2023 | 07:19 PM
That’s the generic 224/234 grind available from multiple cam companies.
Old Sep 14, 2023 | 09:02 PM
72455's Avatar
1972 U code Supreme
So would it be safe to say that it's more aggressive than the stock cam but not as aggressive as the '70--72 W30 cam? Or, where does it place compared to the '70-'72 W30 cam?
Old Sep 15, 2023 | 03:17 AM
Go back and look at my chart. Your cam is 300/310 with 81 deg overlap and .496"/.520" lift. It is less than the 70 W30 MT cam but more than the 70 W30 AT cam. 71-72 are less aggressive. On the other hand, yours has more lift, so total valve curtain area would need to be compared. If anything that's close to the 66-67 cam, but again with more lift. You'd also want to compare lobe separation angle. Olds factory cams tend to have a pretty wide LSA.
Old Sep 15, 2023 | 04:15 AM
BillK's Avatar
The CS198 cam is in the Speed Pro Performance catalog. The description says:
Cam Series: Pro 3000 Idle Quality: Fair Power range: 2500-5500
Doesnt really mean much but figured I would add it to the conversation
Old Sep 15, 2023 | 05:23 AM
Expanded specifications of your cam (SOURCE: SEALED POWER CS-198R - "Speed Pro" Engine Camshaft)
Old Sep 15, 2023 | 06:10 AM
cutlassefi's Avatar
Correct. And a BAD choice if it has the stock comp ratio.
Old Sep 15, 2023 | 07:55 AM
Andy's Avatar
Mark, elaborate please..I am trying to learn something..
Old Sep 15, 2023 | 08:31 AM
72455's Avatar
1972 U code Supreme
Why so?
Old Sep 15, 2023 | 09:17 AM
cutlassefi's Avatar
Lazy lobes, comparatively speaking by todays standards. And the wide lobe sep will stretch the power band. You want to build Cyl pressure earlier not later, cuz you have a low static comp ratio.
Old Sep 15, 2023 | 04:02 PM
72455's Avatar
1972 U code Supreme
I'm not all that savvy on the ins and outs of cam lingo and technology, but I do know that with an Edelbrock performer intake, a Holley 770 Street Avenger, .030 bore and headers, it's got a lot of pull off the line, and it's pretty snappy on the high end as well. I guess the PO did his homework.
Old Sep 16, 2023 | 01:33 PM
cutlassefi's Avatar
So it has a different piston in it, that’ll make a difference.
chips W-30
Jul 26, 2022 09:50 AM
344870M
Jan 11, 2019 10:48 AM
KennyB71
Oct 15, 2015 09:37 PM
w31nut
Apr 12, 2015 06:13 AM
coltsneckbob
Sep 8, 2010 02:36 PM
