W30 cam v 442 cam
Old Jan 10, 2019 | 01:14 PM
344870M's Avatar
W30 cam v 442 cam
This may seem like a really dumb question but here goes. My 70 W30 4 spd (confirmed with broadcast cards) had it's original cam replaced with a standard 70 442 cam. I'm having her completely restored. So she will be getting the correct cam. Here's my question. She ran VERY strong with the wrong cam. What, if anything, will change with the correct cam? I was told once that the W30 cam only really worked with steep gears. I have 433s. Thoughts....
Old Jan 10, 2019 | 03:07 PM
twilightblue28A's Avatar
I had the opposite problem. I put a 4 speed W30 cam in my 1970 W30 automatic and my car ran over a full second slower in the quarter mile. My elapsed time went from 13.28 ET @ 106.28 MPH with the automatic cam compared to 14.40ET @ barely 100MPH with the W30 4 Speed cam.
This was in the strictly stock class, street tires, and factory exhaust.
My conclusion is that my 1970 W30 automatic wouldn't run with the W30 4 Speed cam which was too radical for the 1970 W30 automatic.
FYI: The 1970 W30 automatic cam is identical to the 1970 455/365 442 cam.
I hope this helped.
Old Jan 10, 2019 | 03:35 PM
Run to Rund's Avatar
The 328 degree cam really likes headers and fairly open exhaust.
Old Jan 10, 2019 | 04:17 PM
344870M's Avatar
I hope this helped.
I believe the cam you referenced at the end there is what I had in mine. I'd have to find it to confirm that. But I'm pretty certain that's what it was. As a 4 spd car with steep gears, she ran hard, very hard with this cam.
Old Jan 10, 2019 | 04:20 PM
344870M's Avatar
How does it feel about W/Z manifolds and turbo mufflers? lol
Old Jan 10, 2019 | 04:49 PM
Back in 1973 I ran a 431 with the 328 degree cam and -877 Turbo Mufflers The car was about 1/2 second quicker in the quarter with cheap headers vs. the manifolds, iirc.
Old Jan 10, 2019 | 05:31 PM
83hurstguy's Avatar
It will run fine with the 4.33s. Give it plenty of initial timing. The 328 cam is too much cam for exhaust manifolds, Olds was planning for racers to swap to headers. One of the Pure Stock drags guys switched from a 308 cam in a 455 back to the original 442 cam (285/287 or whatever it is) and the car gained more midrange power, but hasn't been noticeably faster in either configuration. The downside of the 328 is not only the increased duration, Olds narrowed the lobe separation, which increases the overlap. Overlap and exhaust manifolds don't really mix well for performance.
Old Jan 10, 2019 | 06:56 PM
BackInTheGame's Avatar
Thanks for sharing your experiences, guys; stumbling on threads like this is a cool way to learn.
Old Jan 10, 2019 | 09:11 PM
OLDSter Ralph's Avatar
I hope this helped.
Do you have the stock torque converter ? Whats the stall ?
Old Jan 10, 2019 | 09:22 PM
Stock '70 W30 automatic with factory transmission .only change was the 4 speed cam which killed my cars performance.
I swapped back the automatic cam and ran low 13's @ 105-106MPH all day. Yes, only change was the cam.
Old Jan 10, 2019 | 10:34 PM
The 328 cam won't work well with your stock torque converter.
Old Jan 11, 2019 | 03:36 AM
shiftbyear's Avatar
Makes perfect sense. They both have the same lift. We Cam Doctored an original W-30 stick cam about 15 yrs. ago and the numbers were right on. The graph showed with the extra duration they were able to make the opening and closing ramps gentler. This would probably reduce the chance of valve float at higher rpm. Since these were warrantied engines I suspect this was deliberately done to reduce failures. Todays cams and springs can give you much better power. Good luck with your restoration.
Old Jan 11, 2019 | 10:02 AM
I suggest a custom Comp cam like the XE274H but on 112 degree lobe centers for manifolds and max performance.
Old Jan 11, 2019 | 10:09 AM
344870M's Avatar
I appreciate the information. But I am restoring it to original factory condition. All this insight is very interesting though. Thanks
Old Jan 11, 2019 | 10:48 AM
My442's Avatar
I used the 308 duration version in my 1970 442 automatic.
2200 stall and 3.91 gears - the cam worked well.
Decent isle, good vacuum, and power up to 6000 RPM.
SY2455
Mar 27, 2018 10:49 AM
KennyB71
Oct 15, 2015 09:37 PM
w31nut
Apr 12, 2015 06:13 AM
Boiler_81
Dec 11, 2014 01:23 PM
coltsneckbob
Sep 8, 2010 02:36 PM
