cam grind numbers from 455
Old Feb 8, 2014 | 03:41 PM
72cuttys's Avatar
I just tore down my 455 to a shortblock, finally got the cam out. I am trying to find if this is a stock cam, or aftermarket. I cant seem to find anything on it with the numbers that were stamped into it.
From top to bottom:
cr804542
030120
80 34-02
Also, havent looked it up yet but the balancer had 21 1850-2 engraved on it.
Old Feb 9, 2014 | 01:04 PM
72cuttys's Avatar
Ive determined that the balancer is an OEM balancer, still cant find any info on the cam.
Old Feb 11, 2014 | 04:06 PM
BlackGold's Avatar
If it's a factory cam, you will likely find a casting number with digits individually cast in the rough areas between lobes. You will also likely find one to three paint stripes between lobes. You'll have to clean it and use a bright light to see the stripes. If you can find this stuff, I might be able to help you identify the cam. If you can't find this stuff, it's probably an aftermarket cam. Search common cam vendors websites for the numbers you found. I'd start with Crane, since the one number you listed starts with "CR".
Old Feb 11, 2014 | 04:11 PM
This may be it:
http://www.summitracing.com/parts/CRN-804542/
rab62184
Mar 23, 2015 07:04 AM
henryk8398
Ninety-Eight
27
Dec 13, 2012 04:32 AM
BStone
25
Aug 14, 2012 09:35 AM
I'amTheBatman
Aug 10, 2012 12:16 PM
boese1978
Jun 11, 2012 11:33 AM
