Cam break in
Old Feb 27, 2017 | 10:09 AM
jimmymtfan19's Avatar
Cam break in
Would you guys break cam in with one of the springs out (double springs) i have a set of stock 72 cutlass springs also. Or just leave them both in.
Old Feb 27, 2017 | 10:15 AM
svnt442's Avatar
Depending on the lift of the cam, the stock springs might go into coil bind, so I wouldn't use them for that.
A lot of people pull the inner spring to do the break in, but I have never done that. I set up the springs for the correct installed height, and then run the engine at 2000 RPM for 20 minutes. Do an oil change and was on my way. I've never had an issue doing it that way.
Old Feb 27, 2017 | 10:19 AM
Are they really dual springs or is it a single spring and a dampener?
Old Feb 27, 2017 | 02:56 PM
Dual springs no dampner
Old Feb 27, 2017 | 02:58 PM
Also am looking for a good alternator setup. I think they make a one wire ac delco. And you dont have to worry about the stock external regulator?
Mrgadget
Jul 30, 2016 05:47 PM
Oldsmaniac
Jun 20, 2014 05:44 AM
Uncle Hulka
Mar 12, 2014 03:41 PM
nonhog
Jun 17, 2011 01:29 PM
csouth
Jun 3, 2009 09:37 PM
