Cam advice
Old May 16, 2018 | 07:02 AM
67Rocket's Avatar
Cam advice
In the process of doing a basically stock rebuild on a 67 400 engine (E) and would appreciate some recommendations on a good street use cam, good mid range torque. Engine has stock C heads, stock cast quadrajet intake. Hooking up to 2.54 first gear Muncie and 3.23 rear. Thanks.
Old May 16, 2018 | 12:51 PM
cutlassefi's Avatar
Hi Flow AH (220/220@.050) on a real stock type rebuild. If you want something a little hotter then I'd do a Hi Flow 1(228/228@.050).
Old May 16, 2018 | 01:42 PM
Kennybill's Avatar
Your engine takes 0.921" lifters. Some have had a problem getting the ones that are correct. You probably should buy the cam and correct lifters and timing set from Mark instead of making a mistake. I know someone who put the incorrect 0.921" lifters from a olds vendor from California and had a major lack of oil pressure. It was a 1966 Toronado 425 engine.
Old May 17, 2018 | 06:12 AM
67Rocket's Avatar
Thanks for the suggestions, you mentioned Mark, how do I get in touch with him?
Old May 17, 2018 | 07:10 AM
67Rocket's Avatar
I sent a pm to Mark
fv64olds98
Jan 31, 2013 02:56 PM
73supreme
Jul 25, 2012 05:15 AM
Bugg
Mar 10, 2012 02:14 PM
sphinx_57
Jan 23, 2010 06:40 PM
ijasond
May 13, 2008 08:27 AM
