C Heads
Old Apr 26, 2014 | 05:57 PM
Chuxter's Avatar
1970 Cutlass Supreme
C Heads
I've got a mid 70s 455 with J heads on it that I'm putting in my 70 Cutlass, while I was going through my stuff that was in the trunk I found a set of C heads,would these be worth rebuilding and putting on this engine?
Old Apr 26, 2014 | 06:49 PM
dnmfranco's Avatar
The C heads are better flowing heads. Check if the intakes are 2.07 or 2.00
Old Apr 28, 2014 | 10:48 PM
redneck482's Avatar
C heads port out well.. and with a good valve job with the right angles.. you can make them swallow a 2.14 intake valve and get them flowing 278@650 with fat low numbers .. flowing more than stock EDE heads.. but you'll invest probably 30 some hours into them..
Old Apr 29, 2014 | 04:54 AM
Smitty275's Avatar
Engine Builder
Stock for stock you probably wont see a lot of difference. The C heads will probably run a little better.
64 CUTLASS KEN
Dec 7, 2020 06:43 AM
olds4life
Dec 25, 2012 12:56 AM
Oldsmaniac
Nov 1, 2010 06:37 PM
gearheads78
Nov 10, 2009 09:31 PM
DarkStar
Oct 21, 2009 07:35 AM
