Brand new engine with a knock
Old May 6, 2014 | 05:27 PM
442craig's Avatar
Hi guys,
I have a 68 400 motor that is brand new. Roller cam, rockers, forged pistons .030 over etc. It is now knocking when it is revved up. Sounds to me like a rod. What do you think? you can hear it kick in at :12
Thanks,
Craig
https://www.youtube.com/watch?v=koD8...ature=youtu.be
Old May 6, 2014 | 05:57 PM
Could be top end. Check all of your rockers.
You say "brand new" - why not bring it back whence it came?
Old May 6, 2014 | 06:03 PM
Smitty275's Avatar
Engine Builder
Sounds "rocker armish". That's where I'd start investigating.
Old May 6, 2014 | 06:11 PM
442craig's Avatar
The engine builder is out of town. Just wanted to get everyones opinion. I adjusted the valves prior to this. They are all about a half turn tighter than first set. Maybe I'll pull the covers off and try again. I'm hoping that is all it is! Thanks all.
Craig
Old May 6, 2014 | 06:49 PM
dc2x4drvr's Avatar
How are you adjusting lifter preload? The "knock" sounds low, I' would already have the oil filter cut open..
Old May 6, 2014 | 07:05 PM
442craig's Avatar
First attempt was to find zero lash and add a 1/2 turn. I think I am going to try to adjust them running. This is how I've always done it in the past. (non Olds)
The engine builder is highly reputable so I doubt it is anything coming apart.
Craig
Old May 6, 2014 | 07:10 PM
coppercutlass's Avatar
Chevy budget Olds powered
Reputable chevy ford or reputable olds builder. Very different worlds. Im hearing both valve train and lower end noise. Never heard loose rockers knock that loud and I have had 2 rockers fall off because they where so loose that during break in the fell off and made no noise !
Old May 6, 2014 | 07:13 PM
Gary M's Avatar
Is the knocking at rev when its cold only? Mine has forged pistons and it is not good to rev the motor till warmed up because you can scratch the cylinders. The forged pistons expand as they warm up to fit properly and do knock some until then. Either way it is best to park it till he can check it out. I would not even start it again (tow it if you have to) to his shop. Its on him and its in your best interest to take every precaution to protect your investment. Good luck with it.
Old May 6, 2014 | 07:21 PM
442craig's Avatar
He has built big engines since the 60's and is good friends with Joe Mondello's son. I'm hoping he knows what he's doing. I was hoping it was just my crappy valve adjustment but you guys are scaring me now!
I drove it around the block a few times, it idled fine it just makes noise when I put my foot into it. I'm now thinking I'm going to wait for him!
Thanks for the advise!
Craig
Old May 6, 2014 | 07:34 PM
Gary M's Avatar
When I bought my car the motor had 8000 miles on it. No knock, just a rear seal leak. Turned out the thrust was not set proper and ruined the crank. Sorry to scare you but a knock is not a symptom of a rebuilt motor. He should know if it is the sound of forged pistons or something more. I just think in this case less use is better. I would rather spend towing cost than drive a car with possible issues. Regardless of the cause you have the upper hand now because it was just rebuilt by him.
Old May 6, 2014 | 07:35 PM
dc2x4drvr's Avatar
The correct way to adjust lifter pre load on any engine is EO-IC...exhaust opening-intake closing, there are at least a few thousand hits on Google...it's the best way to set lifter preload.
Old May 6, 2014 | 07:45 PM
442craig's Avatar
Thank Gary, He is a great guy and should fix it for me. Better safe than sorry!
Old May 6, 2014 | 07:47 PM
442craig's Avatar
Yeah, It is just a real PIA to do it with the engine in the car! Hard to turn the motor by hand! What do you think about adjusting them running?
Thanks!
Craig
Old May 6, 2014 | 07:48 PM
nsnarsk65cutlass's Avatar
Sounds like bottom end to me.
Old May 6, 2014 | 07:51 PM
442craig's Avatar
Great, you are not helping!
Craig
Old May 6, 2014 | 07:54 PM
Gary M's Avatar
Since he built it he may want to do the adjusting on the lifters. JMO. I did not have to do anything on mine, just drop it in.
Old May 6, 2014 | 07:56 PM
67 Cutlass Freak's Avatar
That sounds like lower end knock to me. What is your oil pressure? What rockers are you using?
Craig
It's hard to tell just from the vid,if it was valve train it wouldn't come and go it would be a constant noise,i think?
Old May 6, 2014 | 08:00 PM
I run forged speed pro's and never heard them knock when its cold.
Old May 6, 2014 | 08:08 PM
Gary M's Avatar
Copper cutlass; now I'm scared.
Old May 6, 2014 | 08:14 PM
As was mentioned look at your oil psi or hook up a mech. Gauge. I once thought I had a rod knock but it turned out it was a really loose motor mount and the header on the dr. Side was hitting the frame when the engine was idling. If you aren't comfortable with the situation just wait until you and your engine builder can truly begin to dig into the issue.
Old May 6, 2014 | 08:28 PM
442craig's Avatar
Thanks all, looks like I'm right back to where I started! I am using the stock oil presure dash gauge and it is indicating halfway (normal)
Stay tuned! I'll post something when he returns!
Craig
Old May 7, 2014 | 04:24 AM
tru-blue 442's Avatar
Old School Olds
Ouch! Wrist pin?
My ears say rod related,
with some top end ticking as well.
Old May 7, 2014 | 04:48 AM
Nilsson's Avatar
That rebuild is a fail, sorry to say.
Good luck.
Old May 7, 2014 | 04:57 AM
Oldsmaniac's Avatar
My 2 cents, is the car an automatic trans? I have heard cracked flexplates sound like that...
Old May 7, 2014 | 06:58 AM
Old School Olds
Good luck.
I must agree. Take it back.
Old May 7, 2014 | 06:59 AM
442craig's Avatar
It is an automatic. The sound seems to be coming from the passenger side
Old May 7, 2014 | 07:46 AM
70cutty's Avatar
Beer Connoisseur
X2. Check the flex plate.
After having my 350 rebuild, I put it back in the car, took it for a spin after breaking in the cam and similar knock occurred. I thought bottom end for sure, turns out cracked flex plate.
It's hard to tell from the video, but I would look into that.
Also What rockers are you running?
I also had a problem with Compcam Magnum Rocker kit that developed a knock after about 300 miles. It turn out to be the heat treated steel pushrods supplied in the kit were getting chewed up and mushroomed by the rockers. I replaced them with Trickflow Chrome moly and now it runs fine.
Old May 7, 2014 | 07:52 AM
442craig's Avatar
I'll check the flex plate! I believe they are Compcam roller rockers.
Thanks for the info!
Craig
Old May 7, 2014 | 08:27 AM
442craig's Avatar
https://classicoldsmobile.com/forums...-begins-6.html
Here is the thread with some images of the roller rockers
Old May 7, 2014 | 08:37 AM
  #31
70cutty's Avatar
Beer Connoisseur
Check the pushrods. Few other CO members had the same or similar problem with them.
Old May 7, 2014 | 08:39 AM
  #32
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
IMO Sounds like a rod. Did you look at the oil and inside the oil filter. My bet is it looks like sliver paint.
Old May 7, 2014 | 09:32 AM
  #33
442craig's Avatar
I did pull the dip stick a few times and wipe it on a white cloth. Looked ok.
Old May 7, 2014 | 01:41 PM
  #34
Old School Olds
Pull the filter, cut it open.
This will give you a tell.
If you find a lot of metal shavings.....
You can tell him to bring his wrecker too.
Old May 7, 2014 | 01:56 PM
  #35
don71's Avatar
same but different
The video doesn't sound good to me either. I'll offer up one more suggestion, I don't think was mentioned. Check to make sure the dampner bolt is good and snug. AKA balancer is tight or not? Good luck.
Old May 7, 2014 | 03:40 PM
  #36
gearheads78's Avatar
car guy
I would not start it even one more time until you cut the filter open.
Old May 8, 2014 | 05:46 AM
  #37
The dips stick will not tell you what you need to know. To properly assess whats going on you need to drain the oil completely in a clean container to see whats in it as well as cutting the filter open to see whats being caught up in the pleats. This is rebuilt engine trouble shooting 101.
Careful cutting the filter open. You cut around the top seam. Dont confuse the metal from cutting with whats deposited inside. Oil filter cutters are available. But careful... Hack sawing or cut off wheelin will do the trick.
And yes do not run this engine until you do this. Ill bet one of the crank journals looks like a beaver was gnawing on it but I hope not.
Old May 8, 2014 | 11:15 AM
  #38
442craig's Avatar
Talked to the engine builder. I am going to check the oil filter. Stay tuned (and cross your fingers!
Craig
Old May 8, 2014 | 01:59 PM
  #39
RROLDSX's Avatar
Fingers and toes bud!
Old May 8, 2014 | 02:01 PM
  #40
442craig's Avatar
Thanks!
