Big Blocks!
Big Blocks!
Are all internals (crank,rods) on 400 and 455 engines interchangeable? 455 cranks and rods in a summit catalog,will they fit a 400? I just want to be sure before I make a costly purchase. Thanks for any info!
big blocks
Thanks 501! Ive heard that the 68-69 400's werent as good as the 66-67's. Would an Eagle crank and aftermarket rods make a 68-69 400 comparable to a 66-67 400 or is the difference between 66-67 400's and 68-69 400's in the block itself? Im looking to either build a 400 or 455 for my 68 442 converible,Ide like about 400 hp but would like it to run on pump gas. I am just gathering info before I start buying parts. Thanks again.
My experience is in locating the parts to restore the 400 engine in mine I'm sure others could give better advice regarding 66-67 vs. 68-69 400's HP and such.
If I had to do it all again...I would have stored the #'s matching 400 put my C heads on a rebuilt 455 w/forged pistons.
I had a hard time finding pistons for the 400 under 800.00 I went with Egge cast aluminum ones for around 500.00, Eagle Rods, Stock Nodular crank and mild Crane Cam.
I have been told the Stock crank is very good so save some cash and put it into the pistons and the heads.
Good luck.
Good luck.
The downside of the 68/69 400 is the small bore. You might want to conatct Bill Trovato at BTR Performance.He did a nice 69 W30 400 engine a few years back,for a concours restoration,but I know there were a few tricks inside.
The 68-69 400 motors used a 3.87 bore and a 4.25 stroke. Rods are 6.735". The crank and rods are common with those in the 455.
70442rag
Dec 30, 2014 09:41 PM
Kidcutty
Mar 10, 2010 06:08 AM
