Big block swap shifter linkage issues
Old Feb 28, 2018 | 09:42 PM
camdon454's Avatar
Shifter linkage issues
Swapped a 455 into my 70 Cutlass S, was a 350 car. Heddman headers barely fit now my column shifter linkage hits the header, not even really close. I was told I needed to swap to floor shift but really don't want to.Anyone encountered this? Appreciate any feedback
Old Feb 28, 2018 | 09:54 PM
camdon454's Avatar
Has anyone experienced problems withe the stock column shifter linkage mating up with a big block swap into a 70 Cutlass S? Rebuilt 350 transmission utilized the original small block motormounts on both frame and block. Heddman headers, long tube, just doesn't even seem close. I've read I need a floor shift? Really don't want that at all, like the look of the stock interior. Any advice would be appreciated
Old Feb 28, 2018 | 10:02 PM
Gerald Nickels's Avatar
The floor shift will not let it run faster. Look at the Hemi 426 cars a auto column shift works just fine.
Old Feb 28, 2018 | 10:07 PM
camdon454's Avatar
Not looking for faster, just want it to work!
Old Feb 28, 2018 | 11:11 PM
4speed455's Avatar
Are you using the 350 headers. If so thats the problem. They may bolt to the 455 heads, but the deck height is taller so your gonna have clearance issues.
Old Mar 1, 2018 | 04:42 AM
You should be able to use your column shift, adjust the linkage in park. The only thing is the indicator pointer may be a smidge off.
Old Mar 1, 2018 | 07:51 AM
Depending on how a particular header manufacturer routed the pipes, you may or may not be able to retain the stock column shift linkage. I've installed many headers that simply did not allow the rod from the steering column to clear, whether it was for a column shifter or the backdrive linkage for the floor shifter. At best, you'll need to bend the linkage rod to clear. If that doesn't work, you can get a cable conversion for the column shift from various street rod shifter vendors.
Old Mar 1, 2018 | 10:57 AM
I was thinking the same thing as he didn't mention if these were the original 350 headers or a new set of 455 headers.
Old Mar 1, 2018 | 01:34 PM
camdon454's Avatar
They are new headers ordered for a 455
Old Mar 1, 2018 | 09:14 PM
svnt442's Avatar
I had flowtech headers on a 70 Cutlass S that was originally a 350 car that I swapped a 455 into with a column shifter and had no issues.
It sounds like the headers just weren't made with the linkage in mind.
Old Mar 2, 2018 | 07:17 AM
camdon454's Avatar
I think the headers I ordered were suggested by Oldcutlass to someone on a post at one time with a Hedman part #. I am going to go to the shop on the weekend and try and take some pictures to post.
Old Mar 2, 2018 | 07:50 AM
Which header pn did you order?
Old Mar 2, 2018 | 08:39 AM
camdon454's Avatar
I will have to check when I get home from work, I still have the box.
Old Mar 6, 2018 | 12:53 PM
camdon454's Avatar
Part number 58150
Old Mar 6, 2018 | 01:13 PM
Those are the correct headers for your application. Can you take pictures of the interference at different angles so we can make suggestions on how to make it work.
Old Mar 6, 2018 | 06:55 PM
Here's a thought. Read Step 5 of the Hedman installation instructions for these headers.
Old Mar 6, 2018 | 06:58 PM
I read it, just need to see what the interference is.
Old Mar 21, 2018 | 10:52 AM
Did you get this fixed?
Old Apr 16, 2018 | 05:10 PM
Macadoo's Avatar
Camdon, I'm getting ready to do the same swap with the same headers and a '71. I'd like to know if you got this solved.
@ Joe, do you have a certain brand of cable conversion linkage you like?
Old Apr 16, 2018 | 05:24 PM
I have not had the need for any, so have no first-hand experience. I know Lokar sells one. Heck, my 1999 Chevy truck has a factory cable operated column shifter. Possibly you could adapt a junkyard version, as I'm sure the Lokar one is not inexpensive.
Old Apr 16, 2018 | 06:44 PM
I'd really like to see pictures of the issue. The op has not been on since March.
Old Apr 17, 2018 | 05:28 PM
Macadoo's Avatar
Would you know, off hand, if the A-body Cutlass has a 2 inch column? And roger that on the salvage yard unit. Even the ididit brand is $170.
I'd also like to know how this turned out. It would greatly inform my swap.
Old Apr 17, 2018 | 06:33 PM
VinMichael's Avatar
My car is a 64 but I had the same problem when I went to hedders. I could not shift it from Park to any of the gears. The rod was hitting the hedder
I cut it in 1/3s then eyeballed it and welded the pieces back together with a MIG so the rod would not hit.
It was a 3 beer job at most. I can take a picture if anyone cares to see
Old Apr 17, 2018 | 06:43 PM
Yes, please. Could you include both ends of the linkage also.
Old Apr 17, 2018 | 08:00 PM
VinMichael's Avatar
Here it is. Was easy to get to since the engine and trans are out. Was just dangling there so I pulled it out.
My car had a 350 in it when this was done. 455 is going in within the next 30 days. Trans is a th350 I swapped in - Jetaway is gone.
https://imgur.com/gallery/1ywNj
Old Apr 18, 2018 | 04:09 AM
Ok, that's not that bad of a cure.
Old Apr 18, 2018 | 04:51 PM
Macadoo's Avatar
I haven't had a chance to take a look at my linkage yet. And the small block is still in the bay because of work and the fact that it won't quit snowing! Is it possible to simply bend the linkage?
Old Apr 23, 2018 | 05:47 PM
Macadoo's Avatar
I'm curious what headers you have for your 455.
I sure wish the OP would let us know how this turned out.
camdon454
Feb 28, 2018 11:11 PM
cfair
Dec 11, 2017 08:31 PM
bspaulding
Sep 3, 2016 04:15 PM
Octania
Apr 7, 2016 02:51 PM
ybicutty
Oct 12, 2012 05:11 AM
