Best Rocker System That Fits Under Stock Valve Cover
Old May 15, 2019 | 08:01 PM
Tjohn8573's Avatar
Looking for opinions on what is the best rocker system system to use that will still fit under Stock OEM notched balve Covers with the baffles. Thanks!
Old May 16, 2019 | 06:05 AM
oddball's Avatar
Define "best"? If you're on stock heads, then the 5/16" stud hole is a definite concern. You won't get a girdle or a shaft mount system under a stock cover.
It's usually not the rockers that cause problems - it's the polylocks. I have the Harland Sharp 5016's with shorty poly locks, a 3/8" valve cover spacer from Rocket Racing and a thick metal core gasket with the later Olds script covers which are much smaller in the corners than the earlier covers. Fits under the A/C bracket.
Old May 16, 2019 | 06:19 AM
Tjohn8573's Avatar
Thanks for your reply. Sorry I will be using stock “c” heads. Mainly wondering if using stock valve covers am I stuck to using just a stock type rocker system or is there any other recommended rocker systems that I should/could go to that would be better but still use the stock valve cover. Thanks.
Old May 16, 2019 | 06:33 AM
ELY442's Avatar
They do sell stock arm with a 1.6 ratio. Take a look at this link
https://www.amazon.com/Cams-1242-2-Energy-Pedestal-Oldsmobile/dp/B00062YE04/ref=au_as_r?_encoding=UTF8&Make=Oldsmobile%7C51&Model=Cutlass%7C572&Year=1970%7C1970&ie=UTF8&n=15684181&newVehicle=1&s=automotive&vehicleId=1&vehicleType=automotive https://www.amazon.com/Cams-1242-2-Energy-Pedestal-Oldsmobile/dp/B00062YE04/ref=au_as_r?_encoding=UTF8&Make=Oldsmobile%7C51&Model=Cutlass%7C572&Year=1970%7C1970&ie=UTF8&n=15684181&newVehicle=1&s=automotive&vehicleId=1&vehicleType=automotive
Old May 16, 2019 | 07:06 AM
70cutty's Avatar
Beer Connoisseur
Roller rockers fit under stock height valve covers. You have to use short poly locks and thick valve cover gasket, like this one https://www.ebay.com/itm/32379678718...m=323796787188
Old May 16, 2019 | 02:30 PM
I bought some 3/8 thick aluminum spacers to fit Harlan Sharp rockers on Edelbrock heads. The stock valve covers fit and clear the rockers with room to spare.
Old May 17, 2019 | 06:29 AM
oddball's Avatar
Yup, pick your favorite setup. The comp roller-tip setup is perfectly fine for most builds. The pushrods and pinchnuts are junk, but they come with the right adapter studs and they're strong enough for typical valve springs.
If you want to move to a full roller, then bear in mind the hole in the head is 5/16". The only true Olds rocker is the Harland Sharp 5016 (and 5017). All the others are actually a Ford rocker which is very similar.
You'll need to get 1" polylocks. Also one or two adjustable pushrods as you'll almost certainly need a custom pushrod length. Do NOT just slap together stuff out of a kit and run it! Check the rocker sweep! You only need to do that on one cylinder. The "check all 4 corners" approach is pretty paranoid.
Old May 17, 2019 | 07:22 AM
Run to Rund's Avatar
Do you need different rockers? I have found stockers to work well even at over .6" lift if the slots are elongated, and up to about 370 lb. open spring pressure. Until recently, NHRA stockers had to run stock rockers and they run over 500 lb. open with stock lift.
Old May 17, 2019 | 01:59 PM
Schurkey's Avatar
Or just drill four holes in each valve cover bafffle just large enough for the poly-lock to poke through. Easy. Doesn't seem to allow oil into the baffle area (no increase in oil burning via PCV.)
Clean out the metal chips from the baffle before use.
Old May 17, 2019 | 03:59 PM
All factory Oldsmobile rockers are 1.6:1 ratio.
Old May 17, 2019 | 05:57 PM
yellowrocket's Avatar
Get in touch with John at Rocket racing. I can say first hand he sells a setup that will work for stock heads under stock valve covers , I have it installed on my new blue project. .
Old May 19, 2019 | 07:34 AM
brownbomber77's Avatar
Ford 1.6 or 1.7 pedestal mount roller rockers have the same dimensions as out stuff. E351 is the 1.7 rocker, and I can't remember the part number for the 1.6s. You can find 'em used all over the place. Otherwise, Scorpion is always a good start. If you're gonna go the Ford route, don't use Proform. Just use Ford Motorsport and NOT the Crane Cams 1.7's that came on the 93-95 Cobras with the Ford PN unless you're using longer stemmed valves
68442CONVERTCO
Aug 21, 2021 10:22 AM
Gooner
Jun 26, 2019 10:24 AM
rpb396@sbcglobal.net
Mar 1, 2017 07:35 AM
BILL DEMMER
May 28, 2015 12:15 PM
oldzy
Jun 1, 2011 08:30 PM
