Best Mechanical Fuel Pump 455
Can I get some recommendations on mechanical fuel pumps?
Need enough to supply for 455 at 500 HP.
Will be adding dual inlet for the Holley Carb, but want to leave fuel lines alone behind the pump to the gas tank.
Would like to forego the the external fuel pressure regulator as well.
Is possible with the right pump that bolts in stock location?
Does addition of Edelbrock aluminum heads play into this equation?
Thank you.
Thank you.
Here's website for engine math,
https://web.archive.org/web/20090404...Calc1.htm#FPHP
Figures you'll need about 40 gpm. Good luck
I'm in the market for a new pump. This thread worked out perfect timing wise. The old chrome holley pump is only showing 3 psi at 4k rpm. Just a mid 12 sec street sbo so if it works for the bbo should for the sbo.
BTW its 30 dollars on amazon and if you have prime its free 2 day shipping. My question is why would someone have to beat on it if its s stock replacement pump ?????? just curious.
On Ebay for less, with free shipping out of Kansas US $27.49
http://www.ebay.com/itm/Mechanical-F...pW~bhq&vxp=mtr
I bought it from amazon 2 day shipping free lol. I got a prime acount so its all good. i got iron heads so im good lol. Missed that little detail lol. For some reason i missed the whole aluminum head deal.
Its OK. Have a good day and enjoy that big pump. Its a doozie. People have reported 7 to 8 pounds of pressure with these.
Awhile back I used a holley red street pump hooked up under my hood temporarily, to pull fuel out of my tank and right through a different style of holley electric pump that was off, for my Holley injection. So if mechanical is not enough...
But that is a good size powerful mechanical
