Headers question
Old Jun 13, 2016 | 07:06 PM
Gianni71Cutlass's Avatar
Headers question
Hi I just purchased a 71 Cutlass with a 350 with aftermarket headers. Will these headers fit on a 455 rocket as well?
thanks
Old Jun 13, 2016 | 07:48 PM
No, they will interfere with things because of the deck height difference between the 350 vs the 455.
Old Jun 14, 2016 | 07:10 AM
oddball's Avatar
Well, depends on whether they are actually small block headers, or if they are big block headers installed on a small block.
The big block has a taller deck, so the headers end up sitting roughly 1" higher. Big block headers have longer primary tubes with a bigger drop to compensate. If your collectors are anywhere near the floor or anywhere near the correct place then those headers won't work very well on a big block.
Folks installing big block headers on a small block is not unheard of. They just look funny since they end up hanging so low, and normally are a major PITA to install that way.
Old Jun 14, 2016 | 08:09 AM
First, header manufacturers wouldn't make different headers for BBOs and SBOs if the same ones fit both.
Second, every header manufacturer routes the tubes differently. The fact is that with some brands of headers, you actually can bolt SBO headers to a BBO and make it work. The fact remains that BBO headers typically have different pipe sizes and lengths to match the larger displacement.
Wyze
Mar 18, 2012 01:59 PM
ziff396
Nov 23, 2011 05:04 PM
WTony
Jun 24, 2010 09:15 AM
WTony
Jun 13, 2010 11:18 AM
mwmjr
Jan 29, 2007 05:28 AM
