Best Header Gasket Brand Recommendation
Hey guys,
In your personal experience which brand header gasket would you recommend on a 69 442 Oldsmobile with a 455.
Been reading lots of threads and lots of people say Fel Pro and then some are recommending the copper Mr Gasket ones.
I have Headman Full length headers....just dont want to change them and than still have a possible leak.
Any help will be appreciated.
Thanks guys
Thanks guys
I use copper header gasket with a thin bead of high temperature silicone on both sides of the gasket on my hedman headers. Never had an exhaust leak yet. You can get these gasket from Jegs or Summit.
Sorry to be a stick in the mud, but my experience is that my header gaskets always end up leaking. I change them once a year pretty religiously. Now I just get the cheapie exhaust manifold gaskets from FelPro since I know they're going to blow anyways.
Flatout Racing rubber coated copper gasket held up great on my 455. 30k miles and no leaks.
Also they can be reused, I've taken the headers off few times and bolt them back with the same gaskets, no issues.
I have a set of Heddman headers from the 1990s on my engine, and while the Fel Pro exhaust manifold gaskets work well on them, they may not work for other headers.
For me, it's because they work fine with my headers, they are available from every auto parts store (as in I don't have to order them), and they are cheaper than header gaskets.
Another vote for the Remflex. I've had them on both shorty and full length headers and never had a problem. And I don't have to re-tighten them all the time like guys complain about with other gaskets. But, as has been said, they can be delicate.
