Bearing recomendations
Old Jul 16, 2011 | 12:40 AM
RAMBOW's Avatar
Ben
I'm finnaly ready to order bearings for my 455 build, so I can mock up the crank and check clearances... and get moving on this thing.
Anyway, in summit i only see two main bearing options...
Sealed Power - SLP-4294M20 - $72.99
Clevite - CLE-MS804P20 - $66.99
Anyone have anything good / bad to say about one of these? am i leaving any options out?
What about rod bearings, any recomendations?
My crank is freshly ground 20/20, and has been bagged and stored. After I check clearances, I plan to have the final "extra" recommended clearances polished/ground in if necessary.
Thanks-
Ben
Old Jul 16, 2011 | 05:29 AM
cutlassefi's Avatar
Thanks-
Ben
Clevite all the way thru. Jmo
If they won't "polish" in are you going to have it ground again? Excessive polishing makes the journal out of round and concave in the middle. Fact
You couldn't be doing it any worse way, fact.
Good luck.
Old Jul 16, 2011 | 05:42 AM
TripDeuces's Avatar
Clevites have served me well over the years. Never used Sealed Power so I have no comment on them.
Old Jul 16, 2011 | 06:35 AM
jensenracing77's Avatar
i used Clevite in the engines i built and never had any trouble.
Old Jul 16, 2011 | 08:02 AM
RAMBOW's Avatar
Ben
Good luck.
This is what i was told as well, and i'm prepared in case it does need to have the final tweaks ground in. $100 is a small price to pay to have the clearances perfect-
Although i do wish now i had not been in such a hurry when i initially sent the crank off for work in december before i had done my research.
Old Jul 16, 2011 | 08:12 AM
dc2x4drvr's Avatar
I used Clevite FM 108 M10 (3/4 Grooved) on the mains, and p/n CB-542 P-10 Rod Bearings.
66ninetyeightls
Sep 23, 2009 07:27 PM
Flye
Drivetrain/Differentials
Jul 30, 2009 10:24 AM
PmL69
Jul 7, 2009 08:10 PM
PmL69
Paint
Jul 6, 2009 05:04 PM
craftsmen22
Jan 18, 2009 02:41 PM
