runs bad when hot??
Old Jul 16, 2011 | 07:53 AM
fasteddi's Avatar
runs bad when hot??
I have a 1962 olds 98 that starts fine and within about 15 minuets runs like crap... when it gets hot it seems to struggle...but idles fine...???
Old Jul 16, 2011 | 09:48 AM
I'd go for the condenser as the #1 suspect.
Works fine when cold, gets bad when it gets hot, reduces spark voltage, so idle is fine, but you don't have enough zap under load.
Could be other things too, but I'd change the condenser (and maybe points while you're in there), reset the dwell and timing, and see if it still does it.
Old Jul 16, 2011 | 10:02 AM
fasteddi's Avatar
ok i know what the points are and where theyre at but where is the condenser and what is it... sorry but im use to efi and ignitions with coils..
Old Jul 16, 2011 | 10:07 AM
fasteddi's Avatar
also when i start it it fine but if i drive it even when the motor is relitivly cool, if i floor it it only revs so high, like mabey 3500rpm....
Old Jul 16, 2011 | 10:09 AM
fasteddi's Avatar
also the car does not rev past about 3500 when im driving it, really i can only apply the throttle so much before it wants to die but when its sitting still it revs ok....
sleroy
Jun 4, 2013 03:16 PM
nj_cutlass72
Sep 4, 2012 08:39 PM
67Olds442X2
Jun 14, 2011 06:20 PM
knighthawk
May 5, 2011 04:32 PM
Oldsproject
Jun 21, 2008 07:03 AM
