BBO tried tricks
Old September 29th, 2018, 11:27 PM
RocketRonnie's Avatar
Help with my 425
Speaking on the 425 engine assuming what do these engine like more, nitrous or turbo? Or a blower?
edit... I renamed the thread
RocketRonnie is offline
Old September 30th, 2018, 05:01 AM
cutlassefi's Avatar
They’re just like any other engine, depends on the combination of compression, heads, cam, intake etc.
cutlassefi is offline
Old September 30th, 2018, 06:21 AM
thanks, I thought maybe due to its squareness the engine might lean to one more. But thanks for letting me know
Old September 30th, 2018, 06:29 AM
What about parts that work. Like I heard BBC pistons and sbf 302 rockers will work? Is this true, if so what other internal could be used in the 425.
What hei, exsaust manifolds, intake and cam, are used a lot.
I guessing I should look for a 750 or 800 qJet
Old September 30th, 2018, 06:40 AM
cutlassefi's Avatar
What hei, exhaust manifolds, intake and cam, are used a lot.
I'm guessing I should look for a 750 or 800 qJet
So are you going power adder or stock? You've mentioned both ways, I'm confused.
Old September 30th, 2018, 08:50 AM
well as much power I can add on a stock block. Just researching at this point
Old September 30th, 2018, 10:33 AM
cutlassefi's Avatar
Stock block will take 600 or so. That’s not the issue.
Old September 30th, 2018, 04:20 PM
What do yiub think will be cheaper to run. Turbo or the juice?.
Old September 30th, 2018, 04:53 PM
I renamed the thread for the sake of not having so many threads open. I will direct all my question on this one. Hopefully together with your experience and my muscle I can get this 425 running and ready to go in my 63 Lesabre wagon(pictured).
so i acquired this engine specifically for the wagon. Engine has B heads, said to be from 1966. In rebuilt condition, supposedly. No carb or much accessories.
it came with a th400 from the same year.
i put it on the stand and pulled the valve covers on was dry and the other had some oil pooled in the corner. Next i will pull the intake to look at the valley, then the pan and rotate it.
pictures to come
Old September 30th, 2018, 05:24 PM
cutlassefi's Avatar
If you’re really thinking about going to the next level, I’d use the new Mahle piston as well as the Scat 7.00” H-beam rod and some main studs. Then go from there.
Old October 20th, 2018, 06:55 PM
rocketralph's Avatar
Make sure of the year and what that motor came out of. 425s, for the three years they were made, had different cam bank angles and lifter bore combinations.
rocketralph is offline
DYSKIE
January 30th, 2019 06:39 PM
rpinnt
July 1st, 2018 11:44 PM
doggonn
June 29th, 2018 06:14 AM
DAN76
November 16th, 2010 02:39 PM
steve19
November 28th, 2008 12:02 PM
Quick Reply: BBO tried tricks
