Back to machine shop
Old Oct 31, 2017 | 05:56 PM
rpinnt's Avatar
My plans have changed and my rebuilt, but never run, 455 is going back to the machine shop to have the crank drilled for a 4 speed. I figure this is the last time to make any other significant changes. It is (will be) a street only car (64 Cutlass.)
It is .030 over with an anticipated 9.5 compression ratio. I have a larger Milodon pan, high volume oil pump, MSD distributor, Edelbrock performer intake, Holley 870 carb Mondello heads & cam, and hooker headers. I was talked out of oil restrictors during the rebuild and still don't know if they are necessary.
Am I missing anything? Would a windage tray be advantageous?
Old Oct 31, 2017 | 06:00 PM
cutlassefi's Avatar
Originally Posted by rpinnt
My plans have changed and my rebuilt, but never run, 455 is going back to the machine shop to have the crank drilled for a 4 speed. I figure this is the last time to make any other significant changes. It is (will be) a street only. It is .030 over with an anticipated 9.5 compression ratio. I have a larger Milodon pan, high volume oil pump, MSD distributor, Edelbrock performer intake, Holley 870 carb Mondello heads & cam, and hooker headers. I was talked out of oil restrictors during the rebuild and still don't know if they are.
Trash the restrictors. What piston and cam?
Mondello heads, hmmm. Aluminum? Ported or just cleaned up?
Old Oct 31, 2017 | 06:34 PM
rpinnt's Avatar
Pistons are a hypereutectic 14.5 cc, cam is hydraulic Engle/Mondello (either JM20-22 or JM22-25, don't remember) aluminum roller rockers, heads are Mondello/Edelbrock aluminum w/ 77cc volume.
Old Oct 31, 2017 | 06:57 PM
cutlassefi's Avatar
Decent combo, should run fine if everything is assembled correctly.
Old Oct 31, 2017 | 10:17 PM
Gerald Nickels's Avatar
What quart pan is it ? I had a 7 Qt pan in my 64 F-85 its a bitch getting in and out.
Old Oct 31, 2017 | 11:05 PM
rpinnt's Avatar
It is the 7 quart pan. Only time I actually installed it in the car I had the front clip off so went in pretty easily.
rootney
Aug 13, 2013 09:06 AM
815Cutlass1972
Apr 21, 2011 07:26 PM
2blu442
Sep 21, 2010 09:23 AM
Olds64
Feb 4, 2010 01:50 PM
cts-v
Mar 12, 2009 01:43 PM
