Hydraulic lifters and stuff
Old Nov 3, 2017 | 01:59 PM
73aussie455's Avatar
Acceleratii maxim rapidus
I'm replacing the junk J heads and doing a piston swap chasing higher compression than the stock 8.5:1 from 1973.
When I swap the heads from J to C heads using Felpro .042" head gaskets and about .004" off the heads, is that going to upset the lifter/ pushrod/ rocker arm clearances, or should the hydraulic lifters take up the slack?
Old Nov 3, 2017 | 09:05 PM
don71's Avatar
same but different
Given the information you stated, the lifters should be able to accommodate this difference/slack.
Anything else going on that you didn't mention? Like machining the deck of the block?
You really should measure this. You'll need a checking push rod and be able to measure the difference to be sure.
bluecab
Sep 14, 2021 07:52 AM
Stevec
Feb 8, 2015 01:25 PM
507OLDS
Nov 12, 2012 06:36 AM
Pryora
Aug 6, 2012 11:30 AM
dallasite21
Jul 10, 2011 08:26 AM
