Auto Gear OILITE Bronze Pilot Bushings
Old Oct 12, 2019 | 10:54 AM
442operator's Avatar
I know its been discussed before, but I just purchased a real OILITE bronze pilot bushing from Auto Gear Equipment in Syracuse for my rebuilt 69 442 400ci. Cost was $18. I put it in freezer over night and it went in with resistance but moved with every hit of the hammer. If you're looking for the correct one, give Nathan a call at 315.471.8141. He was very knowledgeable and helpful.
BTW: I bought the Dorman one first. Its a few thousandths too large and is definitely not OILITE Bronze.
Old Oct 12, 2019 | 11:13 AM
OLDSter Ralph's Avatar
Oilite Bronze is a sintered, porous material that holds oil. It is a bit softer than normal "bronze".
Hint: Freeze the bushing AND driver you will use. Handle bushing with gloves to keep the surrounding air away. Line it up and give it a good smack with a good sized hammer. The minute the bushing touches the crankshaft, it can begin to "grow" (get bigger).
Test the bushing I.D. with a shaft to make sure you didn't roll material inside the pilot hole.
Old Oct 12, 2019 | 01:23 PM
Thanks Ralph. Next step is to check the I.D.
4SPEED67
Feb 21, 2018 05:41 PM
67Rocket
Aug 14, 2017 06:43 AM
MikeManer
Apr 12, 2016 07:42 AM
quentinnw2
Dec 11, 2013 08:50 PM
foo
Drivetrain/Differentials
22
Jun 23, 2013 12:30 AM
