Anyone try a Tremic 5 speed?
Our 71 had a Muncie 4 speed. We then installed a 5 speed Doug Nash/Richmond and It falls out of 4th gear. I Noticed the Tremics are rated to be strong and reasonably priced. Anyone have an opinion about them?
I know a few that have put the Tremecs in their Cutlasses,& I have a 71 442 here with a Richmond 5-spd. Another thing you might consider is an aftermarket gear cluster for your Muncie. Maserio makes a stock ratio cluster,& an overdrive cluster,keeping the 2:20 1st,but bumping 2nd up closer,& making 3rd 1:1,and making 4th .80. Just a thought.I wanted my W30 to look totally stock,& this helps with 3:91-geared cars.
The shifter placement on the Richmond 5-spd is farther back,compared to a Munice 4-spd.The hump will need modified,& if you have a console,the boot assembly will need to be moved back as well.This is what needed to be done on a 71 442 4-spd convertible.
I just did a high horse power rebuild on a Mustang T-5 for my 64. It required a little fabrication to fit but went in with very little work. My car is mostly a street cruiser and I haven't raced it, so I am hoping for a long and happy life together. I estimate that with a 2:95 1st gear and an over driven 5 gear, with my 3:25 axle to have a very fun street car. FYI the car was raced with a Saginaw 4-speed for 10 years before it spit out the cluster gear, the T-5 should hold up better than the Saginaw did.
tmaleck
Aug 15, 2021 08:17 AM
brokeandugly21
Ninety-Eight
30
Apr 8, 2011 03:04 AM
