Anybody know what this is?
Old Jan 4, 2013 | 01:15 PM
jankyrre's Avatar
Found these plastic pieces in the oil pump filter,where did they come from?
Old Jan 4, 2013 | 01:16 PM
Run to Rund's Avatar
They are the nylon teeth from your camshaft timing gear.
Old Jan 4, 2013 | 01:40 PM
Yup, thats what they are. If you already put a timing set on it no worries.
Old Jan 4, 2013 | 02:03 PM
65B01Delta's Avatar
X2
Old Jan 4, 2013 | 02:28 PM
x3.
You can actually see the shape of the teeth.
Old Jan 4, 2013 | 02:30 PM
jankyrre's Avatar
Question
Thanks,but could you give me a deeper explanation on this
Old Jan 4, 2013 | 02:55 PM
don71's Avatar
same but different
The gears used in original applications had a nylon or plastic coating.
This coating was intended to keep the components quiet as not to induce noise and/or vibration.
Hope this helps.
Old Jan 4, 2013 | 02:57 PM
And they won't last forever, so if it hasn't been changed it needs to be.
Old Jan 4, 2013 | 03:04 PM
Okay, here's a timing gear with little obvious wear
(if you look closely, you can see cracks in the nylon between almost all the teeth):
Here is a gear with a nylon tooth chipped off:
Here is a gear with all the nylon off of it, but from a different angle:
I could have sworn I had a good photo of a badly worn gear, but I can't find it, so I had to scrounge.
Old Jan 4, 2013 | 03:27 PM
jankyrre's Avatar
Understood.
Have to check tomorrow if this gear have been replaced.
Old Jan 4, 2013 | 03:31 PM
Redog's Avatar
I found those nylon things in my oil pump screen on the 330 No holes in the screen though
Old Jan 4, 2013 | 06:26 PM
Not one of Oldsmobile better engineering ideas!
Old Jan 4, 2013 | 09:47 PM
Radarman68's Avatar
here is a picture of a worn cam gear from the front, still installed. Note the huge ammount of slop that is present once the nylon coating wears away..
Old Jan 4, 2013 | 11:28 PM
Rickman48's Avatar
It wasn't just Olds - it was ALL G.M!
I ALWAYS replace the timing set when the water pump goes out, usually from 60 to 80 thousand miles!
Heck, you're more than half-way there, and doing it twice is a real PAI!
Old Jan 5, 2013 | 09:50 AM
jankyrre's Avatar
This is how the gear look like.
More to add to my shopping list.
Should I replace the chain and the crankshaft gear too?
Old Jan 5, 2013 | 10:07 AM
don71's Avatar
same but different
Yes, change all three pieces.
Old Jan 5, 2013 | 04:44 PM
Really? I'm a die hard Olds guy, but I have worked on and driven "brand X" (meaning anything not Olds! ) cars. I don't recall any of the old iron engine having nylon timing gears, I suppose its possible the original parts could have been replaced.
Old Jan 5, 2013 | 05:20 PM
Eddie Hansen's Avatar
Matt actually Pontiac were famous for the plastic gears and yup right around 50_80 k miles,
Jankkyre make sure everything is aligned correctly when putting both gears and chain on ( timing marks aligned etc)
Old Jan 5, 2013 | 07:31 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Chrysler too. My buddy had an Aspen RT with the 360 HO. I was shocked when told me it had the nylon timing gears. I assumed it would have the steel double roller like the cop cars. I knew my 76 350 was decent motor. The nylon gear was perfect, no cracks and only minor slop in the chain.
2blu442
Oct 10, 2019 08:14 AM
ent72olds
Nov 6, 2009 03:26 PM
Flye
Jun 17, 2009 11:36 PM
Cameo White
Mar 30, 2009 04:27 AM
denis
Dec 22, 2006 05:03 AM
