Anybody know what this is?
Okay, here's a timing gear with little obvious wear
(if you look closely, you can see cracks in the nylon between almost all the teeth):
Here is a gear with a nylon tooth chipped off:
Here is a gear with all the nylon off of it, but from a different angle:
I could have sworn I had a good photo of a badly worn gear, but I can't find it, so I had to scrounge.
It wasn't just Olds - it was ALL G.M!
I ALWAYS replace the timing set when the water pump goes out, usually from 60 to 80 thousand miles!
Heck, you're more than half-way there, and doing it twice is a real PAI!
Really? I'm a die hard Olds guy, but I have worked on and driven "brand X" (meaning anything not Olds!
) cars. I don't recall any of the old iron engine having nylon timing gears, I suppose its possible the original parts could have been replaced.
Jankkyre make sure everything is aligned correctly when putting both gears and chain on ( timing marks aligned etc)
Chrysler too. My buddy had an Aspen RT with the 360 HO. I was shocked when told me it had the nylon timing gears. I assumed it would have the steel double roller like the cop cars. I knew my 76 350 was decent motor. The nylon gear was perfect, no cracks and only minor slop in the chain.
2blu442
Oct 10, 2019 08:14 AM
