any expert who can see what year ?
Old Mar 14, 2008 | 05:31 AM
Oldsprepp's Avatar
it should be a olds 455.. but can u tell if it is a smogged low comp 72-76
.. or is it a "high" comp 68-72more fun engine...
Old Mar 14, 2008 | 07:37 AM
Well, the "J" on the head tells me it's likely a 73-76 motor. Check the VIN derivative on the pad directly below that "J". The second digit in the VIN derivative is the year of the block. 8=1968, 0=1970, 3=1973, etc. of course, it appears that the motor has been apart before (unless that's just a spray-can "rebuild"), so even if it is a 70s smogger, you don't know what the CR is without checking the pistons.
Old Mar 14, 2008 | 07:54 AM
Rallye469's Avatar
Check out that motor mount!
Was this thing in an old truck? A street rod?
Old Mar 14, 2008 | 08:51 AM
Oldsguy's Avatar
Past Administrator
I noticed that too. I had to do something similar to make a 455 fit in my '46 the correct way.
Old Mar 14, 2008 | 10:24 AM
That yellow is an odd color for an engine.
Old Mar 14, 2008 | 10:38 AM
Yeah, notice how it hides the oil and dirt...
Old Mar 14, 2008 | 01:12 PM
Oldsguy's Avatar
Past Administrator
Probably it was in a yellow car and looked pretty good at one time but it looks like it may have been rattle canned. Since I discovered (re-discovered) brush on enamel I believe that is the way to go. I used POR15 engine enamel but really, probably there are other brands out there that will do as well. Durable, hard, shiny and easy to wipe clean. That paint looks very dull and tired in the photo.
Old Mar 14, 2008 | 02:18 PM
The_Jeremiah's Avatar
Wow, that thing is dirty LOL
Old Mar 14, 2008 | 02:25 PM
Just an excuse to rebuild it.
Old Mar 14, 2008 | 04:53 PM
Pghstarsky's Avatar
I dont care if it's dirty...as long as it would make my car go really fast really quick.
Old Mar 15, 2008 | 02:47 AM
Oldsprepp's Avatar
okey thx for all the tips... these engine's are rare to find here in sweden.. so maybe i buy it and restore it but its no fun if the engine is as power full as my olds 350 that i have in the car now :P then its just alot of work and no gain of speed :P
Old Mar 15, 2008 | 06:20 AM
Rallye469's Avatar
What's your 350 like? (I mean what was done to that?)
Even if you build the 455's bottom end stock and just update the cam...
you'll probably have more power then the 350.
If the J heads are bothering you...you can always just replace them.
I'd say go for it.
Old Mar 15, 2008 | 07:08 AM
Whoa! I missed that. Even here in the US, I'd say snag that motor if the price is right. As I've said before, the last 455 was cast over 30 years ago, so grab any one you can. You can ALWAYS raise compression or port the heads, but casting a new block is tough. Personally, I've been stockpiling BBOs over the last few years. I think I'm up to... uh... well, nearly a dozen so far. Plus a couple of 403s that I got cheap.
Some may remember my motto: Anything under 400 cu in isn't a real engine
Old Mar 15, 2008 | 07:56 AM
J-(Chicago)'s Avatar
Seasoned beater pilot.
and the old....
"There's no replacement for displacement."
Old Mar 15, 2008 | 02:40 PM
Oldsprepp's Avatar
my olds 350 is a "stock" as i know engine that is pretty boring... 0-60 in about 8seconds in my cutlass.
Old Mar 15, 2008 | 02:41 PM
Oldsprepp's Avatar
what ´kind of horsepower was there in the olds 455 with low comp and J heads?
Old Mar 15, 2008 | 02:56 PM
dar83501
Guest
Posts: n/a
I think they were tentatively rated at 260 or 275 horses, if it's a smog motor. Don't recall the torque.
Old Mar 17, 2008 | 06:00 AM
Oldsprepp's Avatar
well well i had bad luck and it got sold before i could go get it
now there are 0 olds 455 for sale in sweden
Old Mar 17, 2008 | 09:11 AM
Rallye469's Avatar
Oldsprepp
Try contacting this guy...he might know where some are hiding.
http://www.oldspower.se/
golds56
Mar 12, 2012 02:52 PM
kjr442
Jul 10, 2011 04:50 PM
Route66Cutlass
Jun 28, 2011 08:56 AM
rod-your-ride
Brakes/Hydraulic Systems
17
Feb 1, 2009 06:46 PM
sharkey1967
Aug 29, 2006 11:45 AM
